3 way frig on gas
Submitted: Wednesday, Oct 24, 2007 at 16:03
Scoof
Just a question to anyone that could explain what could be the problem with my 3 way frig.
I have a chestcold frig freezer 60 litre blue in colour if that make any diff.It seams to work ok on 240 and 12volt but on gas it can't keep up.
We went on a trip to Canarvon Gorge Qld a few weeks ago fired it up at home 2 days b4 leaving on 240 volt no probs pluged into 12 volt while traveling all OK.
But when we got to Canarvon Gorge we had a non powered site so fired it up on gas.After a couple days it was only about 3degrees the diff between outside and inside the frig.The flame looked good it never went out.Could the 240/12 volt system have a different thermostat or what the ?
Cheers Scoof..
Reply By: QLD Kev - Wednesday, Oct 24, 2007 at 16:09
Disconnect the fridge from all sources and put it on it's lid for a few hours then turn it back over and use as normal.
Don't ask me why or how but in most cases this will fix the problem.
Cheers Kev
| Russell Coight:
268147
Follow Up By: Scoof - Wednesday, Oct 24, 2007 at 16:18
Thanks Kev I did do that before I packed away in the shed after the trip so I'm yet to know if it's done the trick.
I was thinking maybe the gas termostat has packed it in , that's if it run seperate from the electric side of things.
Cheers Scoof..
530642
Follow Up By: TerraFirma - Thursday, Oct 25, 2007 at 11:16
Yes that works Kev and secondly most people don't know this, 3 way fridges when running on gas "MUST"be on a flat and level surface, if they are on an angle sloping down they don't work properley.
530815
Reply By: Matt(WA) - Wednesday, Oct 24, 2007 at 17:04
Scoof,
Try cleaning the jet in the gas system. They sometimes block up and will not allow the right amount of gas to burn.
Matt
268155
Reply By: ozwasp - Wednesday, Oct 24, 2007 at 17:11
Hi Scoof
Turning it upside down won't make any diiference as it's working, just not on gas.
I had the same problem with my green F400 explorer and found by getting a toothbrush and some metho or a small wire brush and cleaning around the jet it will increase the gas flow and make it run how it should.
The jets block up due to carbon build up and restrict gas flow, so the ends just need to be cleaned occasionally.
With 3 way fridges, it's best to check they're working properly before you go away - they are good fridges, but need some maintainence.
Cheers, Will.
268156
Reply By: disco driver - Wednesday, Oct 24, 2007 at 17:27
Hi Scoof,
Probably talking to the converted but must ask..Is it level both ways? It should be, Makes a BIG difference when running on gas.
Disco.
268158
Follow Up By: Member - Scoof (SA) - Wednesday, Oct 24, 2007 at 20:10
Hi Disco,
Yep level both ways, made sure of this.
Scoof
530716
Reply By: Phil100 - Wednesday, Oct 24, 2007 at 17:29
Ive had the same problem, clean the jet. the flame looks ok but it will be blocked sl ightly and a clean out will fix it. must be
268160
Reply By: kev.h - Wednesday, Oct 24, 2007 at 17:49
Have had a problem with a wasp nest in the flue pipe would not work on gas all else fine. The electric elements (12 & 240 v) are wrapped on the outside of the flue tube and will work fine but the gas flame heats from the inside therefor any restriction will stop it working dosen't hurt to remove any soot as
well
268164
Follow Up By: Member - Scoof (SA) - Wednesday, Oct 24, 2007 at 20:47
kev I cleaned all that sort of stuff when we were
camping but it didn't seem to make any diff.
Cheers Scoof
530727
Reply By: TD100 - Wednesday, Oct 24, 2007 at 20:29
Hey Scoof,check the little filter inside the gas inlet where the reg connects up to,it is the only minor problem i have had with
mine,the flame looked ok but it was restricted,cleaned him up and away we went(even pull it out if its bad,my mate did that with his)cheers Paul
268193
Follow Up By: Member - Scoof (SA) - Wednesday, Oct 24, 2007 at 20:45
TD 100 I will have a look at that, thanks.
Cheers Scoof
530725
Reply By: Muddies Doe(Trippn) - Wednesday, Oct 24, 2007 at 20:49
Hi Scoof
Also check that a hornet etc hasn't made a home in the flu at the back.
Hope you find the problem soon.
Cya
268197
Follow Up By: Muddies Doe(Trippn) - Wednesday, Oct 24, 2007 at 20:51
oooooooooops, somehow I missed Kev H's answer to you.
530728
Follow Up By: Member - Scoof (SA) - Wednesday, Oct 24, 2007 at 21:31
No prob's M D (trippn)
I need all the help I can get, not much fun with hot beer around
camp.
Cheers Scoof . :-)
530740
Reply By: TerraFirma - Thursday, Oct 25, 2007 at 11:13
The golden rule with these fridges is something nobody ever told me..!
1. You must run them absolutely on a flat level surface, if they are tilted they don't work properley and secondly when you get a chance leave it upside down overnight or for a few hours and you'll be right.
268266
Follow Up By: Scoof - Thursday, Oct 25, 2007 at 11:34
Hi TerraFirma,
When it wasn't working out
camping I got the book out and it says in the operators manual to ensure the unit is level but it didn't make any difference.
On 240/12 volt would it need to be level as
well I asume it would.
What I cant work out is it worked great on electricity but it didn't
even make the cooling plate inside the frig or freezer even feel cold on gas.
How fussy do you have to get when makeing it level by eye good enough or by spirit level??.
I did it by eye then just to check I used a bottle almost compltely full and the bubble was in the centre of the bottle.
Scoof
530819
Follow Up By: TerraFirma - Thursday, Oct 25, 2007 at 11:53
Scoof,
Mine is 10 years old , don't use it much, have a Waeco 40L now but lent it to a mate who is travelling outback, so got the old Chessagirl out for this weekend, and she barked and fired up eventually on gas, don't run it on 12V as they run best on GAS (When they're working).
Level by eye would be fine , have you tipped it upside down overnight..? That fixed
mine once when it was playing up on gas, failing that the jets may need a clean or you could get it serviced. What I do love about these fridges is that whilst they are slow to get cranking once they are away abnd running on gas they are an efficient solution and you don't have to worry about batteries etc etc and can use the
battery power for other things.
530823
Scoof,
mine once when it was playing up on gas, failing that the jets may need a clean or you could get it serviced. What I do love about these fridges is that whilst they are slow to get cranking once they are away and running on gas they are an efficient solution and you don't have to worry about batteries etc etc and can use the
530824
Scoof,
530825
Follow Up By: TerraFirma - Thursday, Oct 25, 2007 at 11:54
oops sorry about my triple up, the PC had a meltdown..
530827
Follow Up By: T.D. - Thursday, Oct 25, 2007 at 12:53
Read your problem with the Chescold fridge and all the suggestions to the cause.I have worked on the for years and agree that it must be leve but if it works on 12v and 240v then the refridgeration unit is ok and after checking for blockages in both the supply line and flue it can only be the gas supply jet.
Clean this with thinners only to remove the varnish type residue which is usually the cause.
Absorbtion fridge problems are either simple or serious yours is a simple one as the unit works ok on 240v
TD
530835
Follow Up By: Scoof - Thursday, Oct 25, 2007 at 13:03
T.D and TerraFirma,
I only turned it upside down for about 2 hours is that good enough.
I will remove it and have another look at the jets.
It has worked
well in the past we had icey poles for the kids when we crossed the Simpson Dessert and ice cold cooper's and wine every night .So I just hope I can fix it.
Scoof.. :-)
530838
Follow Up By: T.D. - Thursday, Oct 25, 2007 at 20:34
Scoof
All turning the fridge upside down does is shif particles of rust on the inside of the sealed unit,which is filled with an amonia solution but that is not necessary as it is woring on 240v. Clean the jet and fire it up level and it will work unless the reg is RS. To
check that try another reg or put a manometer on the
test point on the fridge it should read 11 inch water guage or 2.75kpa
TD
Worn out Gas Fitter
530885
Reply By: flappa - Thursday, Oct 25, 2007 at 13:45
Quote: Could the 240/12 volt system have a different thermostat or what the ?
My understanding of the Eutetic type of fridges is that could be the case.
I dont think the 12v/240v system actually has a thermostat and thats why they are heavy on power consumption.
The Gas has the thermostat.
268278
Follow Up By: Scoof - Thursday, Oct 25, 2007 at 15:21
flappa I think your spot on couldn't find another thermostat.
Thanks to all that replied,
Cheers Scoof. :-)
530848
