Power leads for Caravan? where to buy ?
Submitted: Monday, Oct 29, 2007 at 16:36
ThreadID: 51045 Views:3227 Replies:5 FollowUps:7
HI there - Need a power lead for the Caravan - Jayco -- Is this something i can get from bunnings or do i have to go to a specialty shop ?
thanks
Boc
Reply By: Member - steve H (QLD) - Monday, Oct 29, 2007 at 16:40
try your local Electrical Wholesaler that would be your cheapest option or try a caravan dealer which would be a bit dearer in my opinion.Remember it MUST have 15amp plug & socket.
Steve
AnswerID: 268938
Reply By: kiasen - Monday, Oct 29, 2007 at 16:50
H Boc
I got my 15amp lead from bunnings.
Mike
AnswerID: 268940
Follow Up By: Ozboc - Monday, Oct 29, 2007 at 17:30
excellent -- thanks --- jumping on the bike and going to grab one now :)
Boc
FollowupID: 531744
Follow Up By: Member - Davoe (Yalgoo) - Monday, Oct 29, 2007 at 20:31
yep bunnings - they are a standard item not caravan specific
FollowupID: 531811
Reply By: Member - Doug T (Qld) - Monday, Oct 29, 2007 at 17:33
Boc
Your looking for the wide Pin 15amp Caravan lead; you will find them in most hardware stores, Bunnings , Mitre 10 IN 8m / 10m / 20m
AnswerID: 268950
Follow Up By: Hairy (NT) - Monday, Oct 29, 2007 at 19:31
Gday,
Go on Doug...I dare you to suggest putting a 10 amp plug on the and of a 15amp lead!
LOL
FollowupID: 531776
Follow Up By: Member - Doug T (Qld) - Monday, Oct 29, 2007 at 19:37
Hairy
Don't be bloody silly. ....lol ..that's not how it's done , at the time I used an angle grinder side on because I couldn't find the file, just have to be careful you don't rip the finger nails off.
FollowupID: 531780
Follow Up By: Hairy (NT) - Monday, Oct 29, 2007 at 19:51
Yep...been there done that! These days I use tin snips.....it doesnt get so hot and melt the plug.
LOL
FollowupID: 531791
Follow Up By: Member - Doug T (Qld) - Monday, Oct 29, 2007 at 20:42
Hairy
Use to cut and polish stones in the 60s , the diamond tip saw blade won't cut soft items like fingers, you can push the finger onto the circular blade but hell it can grind into the finger nail real fast ,
FollowupID: 531814
Reply By: Member - Ian W (NSW) - Monday, Oct 29, 2007 at 20:18
Yep!.
Bunnings will be cheaper than a whoesaler unless he gives you trade price.
Have a look in the electrical section, you will find HPM leads specifically labelled for caravan usuage.
Ian
AnswerID: 268996
Follow Up By: Steve - Monday, Oct 29, 2007 at 20:27
I paid nearly $50 at an electrical wholesaler. Only problem is, they don't sell wholesale to blokes who are not trade and they know who is and who isn't. Couple of days later happened to be in Bunnings and saw em for $20. Not the heavy duty one that I had already bought but it would've done me fine.
FollowupID: 531809
Reply By: awill4x4 - Monday, Oct 29, 2007 at 23:06
I've got 2 power leads set up for my caravan, one short and one long one as you never know where the power point is going to be located when you get there. I prefer to use the shortest lead possible and if needed just join two together.
I've done the same with both the water hose and sullage hose as well.
Regards Andrew.
AnswerID: 269037
