uhf radio power
Submitted: Tuesday, Oct 30, 2007 at 23:36
samsgoneagain
does anyone know how to test the transmission power of a
uhf radio. i have a apparently have a 25watt radio but have no way to test the transmission power . any suggestions. its a motorola syntrx
Reply By: stocky - Tuesday, Oct 30, 2007 at 23:39
Buy an RF power/SWR meter and a dummy load from a radio
shop ....
or ask ur local one *nicely* if they will test it for you
be aware - 25w is ILLEGAL on UHF CB
269221
Follow Up By: samsgoneagain - Tuesday, Oct 30, 2007 at 23:41
yes ok thanks. will tread carefully.
532111
Reply By: Member - Kiwi Kia - Wednesday, Oct 31, 2007 at 07:50
What brand and model radio ?
269240
Reply By: Robin Miller - Wednesday, Oct 31, 2007 at 09:06
If your in Melb I could check it for you.
If your in the scrub , grab a tail light bulb and make a connection from the filament to the aerial connector via two short wires (<50mm) and when you transmit it should light up.
P.S. Some people can make this connection with a screwdriver but its a dumb idea unless you get it just right as you could get a
small burn from the RF energy at 25w.
Robin Miller
269252
