Fitting instructions for Milford into '02 HZJ105
Submitted: Monday, Nov 05, 2007 at 21:44
ThreadID: 51318 Views:6143 Replies:1 FollowUps:4
G'day All,
Got a Milford barrier for a 100 series Landcruiser second hand, but no fitting instructions. Can anybody help?
Stu
Reply By: Member - Shane D (QLD) - Monday, Nov 05, 2007 at 22:14
I don't think mine is a milford, but, I'll take a coupla photo's and post em up Tomorrow, may give you SOME guidence
Shane
AnswerID: 270255
Follow Up By: Member - Graham H (QLD) - Monday, Nov 05, 2007 at 22:52
Get in touch with miford and they will fax or email you some if u ask nicely
Start here
http://www.milfordind.com.au/index.php/selectedContent/301266517
If they wont Pm me tomorrow and I will scan mine and send them to you
Whatever you do DONT USE THE HOLES ALREADY THERE as they are not the correct ones Take off your window trims and there are little starter holes pre drilled you have to mark the floor yourself and drill them DONT use the baby capsule restraining holes They are not the right ones
Suggest you dont start till you have instructions as its easy to stuff up and make a mess
Shane If yours is not a MIlford they wont really help as they are rather different between makes and use totally different mounting points. Have looked into this as wanted to mount in unusual place and went thru all the makes and they differ a hell of a lot
FollowupID: 533244
Follow Up By: Member - Graham H (QLD) - Monday, Nov 05, 2007 at 22:54
You also need a fitting kit $70 From TJM and instructions come in it That is if the owner didnt take all the bits out but only gave u the barrier and not all the bolts and nuts etc
FollowupID: 533245
Follow Up By: Member - Shane D (QLD) - Tuesday, Nov 06, 2007 at 21:37
Hi Stu,
I didn't get the opportunity to take photo's as I said I was gunna, My cargo barrier is plated Toyota genuine, (which I think is Milford any way).
Hopefully you got much better info from other respondent.
Shane
FollowupID: 533425
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 06, 2007 at 22:08
Yes the Toyota ones are Milfords but as I said Get a fitting kit cos there is a lot more to it than just chucking some bolts in. There are backing plates for behind panels for strength and the 12mm High tensile bolts. The instructions include with the kit give detailed pics etc on how to install it in both positions. Under no circumstances should the floor holes or the bolts holding the grab handles above the doors be used as they are only 6mm soft bolts
Can send you the instructions but the kit is the wy to go
FollowupID: 533434
