GQ Patrol Turbo 2.8 or 4.2 diesel
Submitted: Sunday, Nov 11, 2007 at 08:18
ThreadID: 51496 Views:10761 Replies:10 FollowUps:3
Looking for advice on which patrol to buy.I am looking at getting a mid 90s diesel patrol to tow a van and want to know is the 2.8 turbo diesel under powered for the size of the car or do I buy the 4.2lt diesel ?
Reply By: Brew69(SA) - Sunday, Nov 11, 2007 at 08:23
Are you comparing a 2.8 Turbo Diesel to a 4.2 Turbo Diesel or is the 4.2 N/A?
AnswerID: 271185
Reply By: Member - Brian (Gold Coast) - Sunday, Nov 11, 2007 at 08:35
2.8 has plenty of power, but you have to keep the revs up to use that power!
I would (and did) go for a 4.2 and, if it's N/A, fit a turbo to it. Plenty of low end for off road, beach etc etc, and on the highway, more pull than a busload of teenage boys!
Brian
AnswerID: 271186
Follow Up By: giffo - Sunday, Nov 11, 2007 at 12:16
The 4.2 N/A !
FollowupID: 534180
Reply By: Member - Davoe (Yalgoo) - Sunday, Nov 11, 2007 at 12:25
the 2.8 will have far more grunt than the 4.2........................... after you do what most people like bilbo did and use it as a cheap way of getting a patrol and shoving a big diesal V8 in it
AnswerID: 271207
Reply By: Ozboc - Sunday, Nov 11, 2007 at 13:25
I have the 4.2 TD -- tooka while to find a 4.2 as people dont sell them once they own them :_ the 3 litre is a dime a dozzen
very happy with this beast -- i use mine to tow a Jayco Flamingo ( 1250 Kg ) and have no probs at all - also run mine on home made Bio diesel.
for me the choice is simple 4.2 TDI every time
Boc
AnswerID: 271210
Reply By: Member - Luke (SA) - Sunday, Nov 11, 2007 at 18:02
Go for the 4.2 and fit a turbo if the speed factor up hills bothers you. I haven't owned a 2.8 but from what I have heard and read on hear the 4.2 is the way to go
Cheers Luke
AnswerID: 271244
Reply By: giffo - Sunday, Nov 11, 2007 at 18:51
Thanks for the advice as this will be my first 4x4,I dont count the outback I drive to work as a 4x4,also is it a problem to fit a turbo to older motor eg 200k and will it cost a arm and leg ?
AnswerID: 271254
Follow Up By: Truckster (Vic) - Sunday, Nov 11, 2007 at 22:40
200k klms just run in.. not a problem - but saying that, depends on service history.
cost round $3800 up.
FollowupID: 534254
Reply By: Member - Barnesy (SA) - Monday, Nov 12, 2007 at 01:19
I love my 4.2 diesel and that's what I would recommend. As others have said the 2.8 needs to rev a lot harder to do the same work.
The 4.2 also has the heavier duty, bulletproof, gearbox and running gear that the Nissans are famous for. The 2.8 doesn't.
When towing it isn't the fastest beast but it will tow anything for any length of time.
Barnesy
AnswerID: 271313
Reply By: Member - Bucky (VIC) - Monday, Nov 12, 2007 at 08:21
Look at it this way
2.8 TD light duty 4x4, uses Nissan car components, eg gearbox
4.2 TD heavy duty 4x4, purpose built and tough, probably best on market.
Guys at work, have both, and by all reports, they almost get the same economy.
Cheers Mate
Bucky
AnswerID: 271323
Reply By: ch00k - Monday, Nov 12, 2007 at 14:02
Giffo,
If you decide to go with the 4.2 I have one for sale.
1994 RX with aftermarket turbo fitted.
198,000K's on the clock.
Bull bar with 2 spotties as well as roof rack with Rhino bag
Well maintained, I change the oil religously every 5,000K's and the fliters every 10,000K's.
SHMBO reckons its getting too big for her to handle.
asking $12000.
AnswerID: 271362
Follow Up By: giffo - Monday, Nov 12, 2007 at 18:43
chook give me a call on 0447 118002 work mobile !
FollowupID: 534355
Reply By: giffo - Monday, Nov 12, 2007 at 19:47
Thanks for the info on the running gear as I had no idea ,I thought only the motors differed.That makes my mind up which way to go !
AnswerID: 271401
