Exhaust System Question
Submitted: Monday, Nov 12, 2007 at 08:55
Member - Doug T (Qld)
Would a Modified Exhaust system i.e 63.5mm cause an older engine to burn more oil due to less back pressure.
I don't ask many questions here but this is one that has had me thinking for many years.
Doug
Reply By: Nav 8 - Monday, Nov 12, 2007 at 09:13
The answer Doug is no not at all. Nav.
271333
Follow Up By: Member - Doug T (Qld) - Monday, Nov 12, 2007 at 09:16
Are you a qualified mechanic or have personel experience to be giving such a firm answer
534286
Reply By: Member - Doug T (Qld) - Monday, Nov 12, 2007 at 10:08
Nav 8
Just giving your answer some more thought , I guess your right if the muffler was the same, what about a straight through system ...No pressure .
Doug
271346
Reply By: Nav 8 - Monday, Nov 12, 2007 at 14:12
G`Day Doug,, Yes mate, qualified mechanic now retired ,30 years in the trade. The exhaust system will have no affect on oil consumption whether it has a muffler or is straight through. Some engines in particular two strokes do rely on back pressure to operate efficiently. Four stroke engines generaly breath better with a larger or less restricted exhaust system and increases what is termed in the trade as (volumetric efficiency). In simple terms that means by reducing friction or resistance and allowing as much air/
fuel into the cylinder as possible for a petrol and as much air as possible for a diesel.The only thing that will cause oil burn is engine wear,eg worn rings/
bore or glazing of the cylinder walls but glazing is mainly related to stationary diesel engines. Hope this has answered your question. Regards Nav.
271363
Follow Up By: Member - Doug T (Qld) - Monday, Nov 12, 2007 at 21:33
Nav
Thanks for a most sensible answer, My 4x4 now has 713,000 + and runs like a dream and might use 1lt in 10,000 Ks . It has Extractors but I have yet to fit the second section from the drivers door back.
Doug
534384
Reply By: TerraFirma - Monday, Nov 12, 2007 at 14:22
Doug, Might be time for some FTC Decarboniser via www.costeffective.com.au.
I use it and it works, run some for 4 tanks or if you have any questions contact the team there. (I'm not trying to sell it, just a possible recommendation)
Some of the benefits:
FTC Decarbonizer: Especially for engines that don't work hard enough for long enough (eg excess idling, light loads, short runs and cool running).
FTC improves emissions, oil control and compression by removing cylinder glaze and top ring carbon. It removes carbon from combustion and exhaust spaces, letting the engine breathe better. It removes carbon from turbochargers, allowing full turbo speed and air delivery.
FTC is particularly suitable for boats, underground mining equipment, crane trucks, street sweepers, concrete trucks, site tippers, loaders, excavators, etc. FTC also produces a faster
271365
Follow Up By: Member - Lionel A (WA) - Monday, Nov 12, 2007 at 17:42
TF....FTC also produces a faster..........???
Now that you have my complete and utter attention Im hanging out for the end of your sentence....lol
Cheers....Lionel.
534343
Follow Up By: fisho64 - Monday, Nov 12, 2007 at 23:49
"FTC also produces a faster --------mousetrap!
sounds like everything is faster, should be flogging it to QANTAS, wouldnt need the A380's if they just put it in the 747 tanks!
534418
Follow Up By: TerraFirma - Tuesday, Nov 13, 2007 at 12:08
A faster Burn..!
All jokes aside I reckon the FTC Decarboniser is a great product but I wouldn't be selling it to Qantas. Now Diesel powered Jets... thats another thing..!
534474
Reply By: 96 GXL 80 series - Monday, Nov 12, 2007 at 19:29
Doug,
if it is blowing blue smoke? jam a cork up the exhaust and that will stop it.
Hope this will solve your pollution woes.
271395
Follow Up By: Richard Kovac - Monday, Nov 12, 2007 at 22:18
96
Are you a qualified mechanic... LOL or GSP, Garmin,, now let me thing... :)
Have fun
Richard
534394
Follow Up By: 96 GXL 80 series - Monday, Nov 12, 2007 at 22:29
Hi Richard,
I am that good, I once applied for a position vacant advertisment that I had placed in the local paper, and to my amazement got the job.
1 day when you have 6mts to spare I will tell you how good I really are. :}
534399
Reply By: Member - Ruth D (QLD) - Tuesday, Nov 13, 2007 at 15:29
Hi ya Doug (and Dusty) where are you? Or should I say, are we there yet? Your question is too difficult because I'm a girl so I'm really just saying Hi. Poured the concrete for the footings this a.m. and they will start the frame tomorrow - yahoo. Got a new culvert too so you just drive straight up towards the big roller doors now.
271496
Follow Up By: Member - Doug T (Qld) - Tuesday, Nov 13, 2007 at 21:14
Ruth
Seems to be some undesirables lurking around the
forum so will MM
534573
Follow Up By: Member - Ruth D (QLD) - Wednesday, Nov 14, 2007 at 08:10
Oh Doug, NOT undesirables! I though they all moved to the
Daintree.
534634
Follow Up By: Member - Doug T (Qld) - Wednesday, Nov 14, 2007 at 08:31
534640
Follow Up By: 96 GXL 80 series - Thursday, Nov 15, 2007 at 00:39
You moving house or State DT?
534819
