O/T Yet another "senior moment"
Submitted: Monday, Nov 12, 2007 at 19:54
Mr Fawlty
Despatched by SWMBO to see why the cruise control was not working on her Jazz and discovered that the actuating wire that connects to the throttle cable had parted company so decided to replace with a short length of 4mm ball chain.....
Ok all goes
well I held the throttle open with a small piece of timber to give me some slack in the cable to do the work.... Job finished I forgot about the small timber "sprag" and started up, the engine raced, I tapped the throttle apparently just enough to take tension off the sprag which fell out of the place it was put.
Backed out for a test run and discovered that I can't engage second gear.... I endure a tirade from SWMBO who insists that it was all ok untill I touched it, I try to explain that I did nothing to the gearbox...... Ok back into the workshop to see what is going on and to my total humiliation and embarrasement discover the little wooden sprag wedged on top of the G/B exactly in position to stop the gizmo moving into 2nd gear....
I'm gonna give up this do it yourself servicing, and thanks for being so kind as to not have told the
forum about this before as I know some of you must know as SWMBO spent the rest of the day on the phone ranting about it to all her rellies and even the talking clock got an earfull....
Reply By: Robin Miller - Monday, Nov 12, 2007 at 19:59
Only those who do things can make mistakes
Robin Miller
271403
Follow Up By: Mr Fawlty - Tuesday, Nov 13, 2007 at 17:45
Hmmm I think it's actually "those that can do - those that can't teach"
534518
Reply By: Wayne (NSW) - Monday, Nov 12, 2007 at 20:56
Mr Fawity,
I would look at this as not a senior moment but as a refinement to the vehicle with safety in mind.
This small piece of timber or should I say this engineered wedge of renewable, recycled timber was used as a speed limiter for going through school zones and in pit lane at the V8 races.
This device, even though a prototype and will need some more refinement, could safe the lives of children and also save you and your partner from speeding fines in school zones.
She should be thanking you and allow you to continue the work that you have started for the sake of mankind.
Keep up the good work and don't let this set back put you off from bigger and better things.
Wayne
271413
Follow Up By: Member - MUZBRY (VIC) - Tuesday, Nov 13, 2007 at 09:09
Here here
534454
