Would you weld in a frame to fit out the troopie?
Submitted: Tuesday, Nov 20, 2007 at 17:17
ThreadID: 51818 Views:3262 Replies:7 FollowUps:18
One of my brothers has offered to weld in a steel frame into the back of the troopie - the other brother has said not to do it. Any ideas on this? All suggestions greatly appreciated. Thanks. Of course, I have to work out what I want where first.
Reply By: blue one - Tuesday, Nov 20, 2007 at 17:38
Build up the frame and using existing tie down points bolt it in.
AnswerID: 272751
Follow Up By: orange - Tuesday, Nov 20, 2007 at 19:16
Thanks, that makes sense.
FollowupID: 536059
Reply By: Member - Oldplodder (QLD) - Tuesday, Nov 20, 2007 at 17:45
Use existing bolt points.
I would be worried about welding it in and body flex cracking welds.
Bolted connections have a bit more give, but can rattle loose.
Use nylock nuts?
AnswerID: 272752
Follow Up By: orange - Tuesday, Nov 20, 2007 at 19:19
Thanks for explaining why I shouldn't weld it and what to use. That was going to be my next question.
Cheers.
FollowupID: 536062
Reply By: Hairy (NT) - Tuesday, Nov 20, 2007 at 18:12
Gday,
What exactly are you building and why would you want to weld it in?
Without knowing what your doing I would say NO!
Bolts are better for most applications.
AnswerID: 272763
Follow Up By: orange - Tuesday, Nov 20, 2007 at 19:14
Gday Hairy,
I want to set it up so I can sleep in it and have storage underneath. I don't want the false floor system cause I want to sit in it sometimes as well - I think. So two storage systems down each side and aisle down the middle, with seat at back. Haven't worked out any dimensions yet. Bolting seems to be the way to go - you always get such good advice here.
Thanks for comments.
Orange.
FollowupID: 536055
Follow Up By: Hairy (NT) - Wednesday, Nov 21, 2007 at 00:34
Gday again,
By the sounds mate......Absolutely not!!!!
There doesnt sound to be any reason for welding to your car.
Maybe go to an engineering firm, tell them what you want (you might be suprised) and see what they say...Dont bull to them ..they might even give you a few ideas??
FollowupID: 536180
Reply By: Member - Brian (Gold Coast) - Tuesday, Nov 20, 2007 at 19:32
Orange,
Recently, like in the last 12 months or so, Australian 4WD Monthly did a fit out on a troopy that sounds like what you want. You might be able to get a hold of the issue through their back orders dept.
Brian
AnswerID: 272782
Follow Up By: orange - Tuesday, Nov 20, 2007 at 20:06
Brian,
Thanks, I'll track it down. I've been surfing the net but have found little in the way of alternate designs to the false floor system.
Regards, Orange.
FollowupID: 536085
Follow Up By: Member - Roachie (SA) - Thursday, Nov 22, 2007 at 08:11
Yeh, I recall that article too. It was designed for a single bunk on the driver's side above the wheel arch, with storage underneath......... a aisle in the middle and on the passenger's side there was a fridge on a slide at the back (between the door and the wheel arch), then he'd built up a cupboard/bench etc.
He could sit on the bed and use the bench for his computer as well as food preparation. It seemed a bit cramped for my liking and certainly only catered for somebody sleeping in there on there lonesome!!!!
FollowupID: 536406
Follow Up By: QLD Kev & Darkie - Thursday, Nov 22, 2007 at 08:17
I think the fridge was on a slide that just fit through the smaller door on the back of the Troopy as well.
Kev
Russell Coight:
FollowupID: 536408
Reply By: Willem - Tuesday, Nov 20, 2007 at 20:50
I use MDF for all mods inside my vehicle.
Go to my website below, click on 4x4 and then scroll to bottom of page and click on Travelling Set-up. In there are some pics of my latest rear storage/sleeping compartment.
AnswerID: 272811
Follow Up By: orange - Tuesday, Nov 20, 2007 at 23:06
Thanks for sharing your website. I looked at storage area. It's interesting to see how it fits together and good for 'ideas collecting' to see what other people have done. I enjoyed reading your wife's art career, too. I'm planning to be a novice painter when I travel next year. I'm going to print off your list of what you take - it looks like a great checklist.
Once again, thanks.
Loris
FollowupID: 536160
Once again, thanks.
Loris
FollowupID: 536161
Follow Up By: Willem - Wednesday, Nov 21, 2007 at 07:54
Hi Loris
Whilst what I have done to the back of my GQ may not be what you are thinking of it does give one new ideas.
I like working with MDF. It is strong and one can use it for any application one desires. And it is re-usable whereas with a welding job, once its done, there is no return....:-)
Yes, art is a big thing in our family. My wife runs the local Art Centre and at the moment a Mosaic feature is nearing completion. We managed to encourage Work for the Dole fellas to take an interest and they have come up with a great design.
FollowupID: 536198
Reply By: 75Troopy - Tuesday, Nov 20, 2007 at 21:21
I used the old points for fitting the seats..
Also if needed extra anchor points in the floor, easy to remove later.
Matt
AnswerID: 272821
Follow Up By: orange - Tuesday, Nov 20, 2007 at 23:12
Istill have side seats in. Assume when I take them out (which I have to do if I don't want to go over the pits again) there'll be points for fitting. Ease of adding and removing points is a good point. Thanks.
FollowupID: 536164
Follow Up By: V8 Troopie - Wednesday, Nov 21, 2007 at 00:23
I also used only existing screw points to fix a bed/ storage under frame in the back of my troopie. One thing you should take care of is when removing the bolts of the seats & seatbelts, especially the ones on the floor, is making sure the weld nut thread gets not damaged by grit/rust adhering to the bolt thread protruding under the car. If it starts getting hard to unscrew DONT force it, you'll damage the thread. It cost me the price of buying a suitable tap (M10x1 I think) to repair the damage caused by being impatient.
The other thing I did was replacing the sidewall covers with thin plywood ones which had pigeon hole type storage bins built in - 3 on each side.
Klaus
FollowupID: 536177
Follow Up By: orange - Wednesday, Nov 21, 2007 at 19:05
Klaus,
Thanks for the advice. The pigeon holes sound like a good idea. I've only found one picture of troopie set out with bed/storage under and row of higher cupboards on other side with fridge on top. Seemed ok - it gives a single bed that way. I'll be doing it in January so have some time to let ideas gel.
Regards, Loris
FollowupID: 536307
Follow Up By: V8 Troopie - Thursday, Nov 22, 2007 at 00:35
A few more details Loris. Despite what others said, there IS merit in doing that frame in steel. I used 20x20 square tubing for the bottom frame and folding out double bed, the next smaller size tubing for supports and attachment pieces. Brackets to the body screw locations were in flat steel.
Basically it is a single bed size frame on the driver side which was high enough to fit a modified Engel fridge on runners underneath. This takes up about half the storage space, the forward end was for general storage. The bed frame is double hinged, once to be able to lift it up for top access to the fridge and storage (this did not require to open the wider back door for quick fridge access).
The bed frame coud fold out for a double bed which was supported on square tubular steel struts at bed level to receivers on the passenger side. These struts were stored by sliding inside the open ended bed frame from the rear.
I left the forward passenger side rear seat in place so one could sit inside the back for a snack on a rainy day, the folded bed top providing a table for the food tray.
Under the hinged rear troopy seat a plywood box had space for tools and other bits. Just behind the drivers seat in front of the bed frame is another plywood box for the 2nd battery. The floor is also plywood, much easier to clean and warmer underfoot than the ribbed steel.
The bed box was clad in plywood panels via welded on tangs on the square tubing.
The whole lot needs careful planning to utilise the existing screw locations but it can be done.
I think the 17 odd years my troopy camping outfit has been in use is ample proof that steel and plywood IS a durable method, nothing has broken so far and I would bet its as light as a MDF/ wood frame. The lot travelled up the full Canning and then around Australia in the early nineties.
Klaus
FollowupID: 536377
Follow Up By: orange - Friday, Nov 23, 2007 at 17:41
Klaus, Thanks for all the details. I'll get one of my brothers to read it - it seems pretty thorough. It would be good to get a double bed in there - although I will be travelling solo. I might find someone silly enough to share it with me.
Regards, Loris
FollowupID: 536686
Reply By: Jimbo from Best Off Road - Wednesday, Nov 21, 2007 at 08:07
My suggestion, from experience, is steer clear of steel.
It is heavy and lacks flex.
Plywood is strong and light. Allows flex and doesn't rattle.
Wood is a wonderful natural material. It has been successful in boats for thousands of years and still is. It is also so easy to work with. Any future modifications or additions are simple.
AnswerID: 272884
Follow Up By: orange - Wednesday, Nov 21, 2007 at 19:08
Yes, wood is the way to go.
What is the difference between plywood and MDF? Is there any advantage of one over the other?
FollowupID: 536309
Follow Up By: Jimbo from Best Off Road - Wednesday, Nov 21, 2007 at 19:15
Ply is stronger and lighter than MDF at any given thickness.
MDF swells badly if it gets wet, not from a sprinkle, but if you sink your vehicle tou will bugger your work. Ply is almost totally water resistant. However do not get conned into the extra expense of marine ply.
Jim.
FollowupID: 536312
Follow Up By: orange - Thursday, Nov 22, 2007 at 00:01
Thanks, Jim. Looks like it's ply.
FollowupID: 536374
