Wirring driving lights on 2006 model hilux
Submitted: Sunday, Nov 25, 2007 at 11:59
ThreadID: 51955 Views:5474 Replies:4 FollowUps:2
Can anyone please help me out very quickly??Iam trying to put a set of light force on a late model turbo diesel hilux and having a bit of trouble,I have done all it says on the wiring diagram,The lights all work right untill i go and turn all the lights off,And the driving lights stay on??????Any help here would be great.
Thanks Jon
Reply By: donks1 - Sunday, Nov 25, 2007 at 14:02
hi there
at a guess you have either a dodgy relay or have picked up the wrong "power supply " line out of the loom
can you hear the relay clicking on and off???
donks
AnswerID: 273606
Reply By: 96 GXL 80 series - Sunday, Nov 25, 2007 at 15:47
You must have connected the + from the battery to the high beam side of the relay.
Check the wiring out again.
AnswerID: 273617
Follow Up By: jonboy - Sunday, Nov 25, 2007 at 15:52
It all works fine untill i go and turn the lights off,Thats when the spotlights stay on untill i turn them of at the switch?the do what they are meant to do when i put the high beam on they come on and the same when i turn high beam off the spottys go off??
Please help me.....
FollowupID: 537010
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Nov 25, 2007 at 16:29
The new Hilux is negative switching.
Run the relay's coil to the headlight. Don't ground the relay.
AnswerID: 273620
Reply By: Member - Olcoolone (S.A) - Sunday, Nov 25, 2007 at 18:16
Red with yellow trace is the switched negative supply on the left and right hand light that turns on high beam.
Black is positive on the right hand light and red is positive on the left hand light, both the black and red wires have power all the time.
Connect the red with yellow trace to pin 86 and the red or black wire to pin 85 of a relay, pin 30 via a 20 amp fuse to the battery and pin 87 to te positive of the spot lights.
Regards Richard
AnswerID: 273637
Follow Up By: jonboy - Monday, Nov 26, 2007 at 22:07
Thanks guys for the help
You were spot on
Chers Jon
FollowupID: 537209
