Monday, Nov 26, 2007 at 21:58
Hi Steve - It costs $2300 up front. You get $2000 back as rebate from fed govt. Maybe worthwhile doing it sooner rather than later in case trusty kevin07 decides he would be better off with the cash instead of handing out rebates??
It is in getting done today and I pick it up tomorrow. The only other cost is a Flash Lube Kit which is $70 but not essential. Depends on your thinking for that item. So the minimum out of pocket cost to you is $300 or maximum $370.
Jamie also gives you a car as a loan vehicle if you need it and is cost free for your use. He normally takes 1 1/2 days to install. He said he has done more Prados than any other vehicle. Keep in mind you lose your 90L petrol
tank but when you put your mind to it there are ways around it if that causes a problem. (problem will probably be in your head really). He fits filler inside the existing flap and utilizes existing
fuel guage on dash etc.
I get same economy as you and only did 7000kms last year in it. I believe I will get better resale one day and I get to save now also and I want the rebate just in case it ends up going or getting reduced. I will use the savings in running costs for other add ons, eg rear camera, tinting, on my van or holidays etc. I have spoken to many many people who actually have LPG installed and I have not had one bad bit of feedback. Also takes Jamie around 4 weeks to get the gear in for you so if you want before xmas you better put the foot down....
Give Jamie a call or two to answer your questions, he doesnt mind and is real easy to get along with. Also ease your mind by talking to people in car parks, on the road etc like I did. Cheers Mick
537204
