Wednesday, Nov 28, 2007 at 17:09
The power figure printed on the lamp is the power drawn from a DC or 50 Hz power source (in the case of a fluorescent tube it only applies when it is fitted into a fitting with power factor correction - the cheap fittings often do not have PF correction and draw more current.)
The different types of tubes have different efficiencies. Their light output is generally related to a standard incandescent globe.
A QI globe produces around twice the light output.
The older fluoros produce around 2.5 times more. The old 40 W tubes produced the output roughly the same as a 100 W globe. The new tubes that fit that fitting draw less.
The high efficiency fluoros produce 5-6 times more (the PL or 2D tubes.) That's the marvels of modern technology
In addition, the PL and 2D tubes seem to be more efficient when operated on power that has a frequency higher than 50 Hz. That is why the caravan manufacturers are turning towards them. The 14W 2D tubes in my van only draw around 1 A. The
inverters in these fittings operate at a frequency of 25 KHz or higher.
537519
