Stabilizing bars on 80 series LC
Submitted: Wednesday, Nov 28, 2007 at 09:13
KSV.
Have read somewhere (4WD monthly?) that it is not big harm for road handling to completely disconnect and remove them. In return it will much improve wheel articulation off road.
Any comments?
Serg
Reply By: Member - Leave_enough_space - Wednesday, Nov 28, 2007 at 10:24
KSV,
The instructions that came with my hitch say:
"Whilst driving, it should always be observed that the Weight Distribution system be disengaged (ie release Spring Bars) when: negotiating rough, uneven terrain; entering or leaving driveways, short steep gutters, access ramps, speed humps and dips; negotiating tight, acute turning at low speeds; or when travelling up/down steep abrupt inclines (ie severe, undulating road surfaces)."
This is exactly as written, including poor grammar, & possible missing words!
Hope this helps?
LES
274026
Follow Up By: Gone Bush (WA) - Wednesday, Nov 28, 2007 at 10:27
Les, I think Serg is referring to the stabiliser bars across the axles of the 80 itself, not WDHs on a van.
Hey Serg is it true that "jetski" is Russian for jetski?
537450
Follow Up By: KSV. - Wednesday, Nov 28, 2007 at 10:33
Thanks, but nope, this does not helps.
My question was about factory stabilizing bars – those two “C” shaped and funny curved rods in front and read.
Serg
537451
Follow Up By: KSV. - Wednesday, Nov 28, 2007 at 10:36
Gone Bush,
Are you asking how we call jetski in Russian? Something like “
water bike”.
Serg
537452
Follow Up By: Member - Leave_enough_space - Wednesday, Nov 28, 2007 at 16:55
Whoops! sorry Serg, I didn't read the question as thoroughly as I should.
537513
Reply By: Robin Miller - Wednesday, Nov 28, 2007 at 10:25
There can be "Big Harm" if the car sways to much at road speeds which is why it needs to be done with care, and why some use links to disconnect the sway bars off-road and re-connect when they get back on road.
In practise these can be a pain.
For my car, a patrol I did a lot of experimentation. Removing both sway bars was to much. Removing the front only gives the most articulation increase however steering control was adversely affected.
My current set up is that the rear and its components are removed , and I fitted adjustable shocks to partly compensate for the side effects.
Robin Miller
274027
Follow Up By: KSV. - Wednesday, Nov 28, 2007 at 14:31
Thanks for sharing - interesting and informative.
Serg
537485
Reply By: Moose - Wednesday, Nov 28, 2007 at 15:23
G'day Serg
Yes they can be removed without dire consequences.
I once broke a bracket that holds them on whilst travelling up to
Cape York and had to remove it. I'm pretty sure it was the front one (this was many moons ago!).
It certainly made the vehicle rock more from side to side. Finished the trip up and back (both ways on the Telegraph Track) and then back to Brissie without any harm.
BUT, having said that I'm sure Mr Toyota didn't put them there for the sake of it so they obviously are intended to be attached. I assume that better on-road handling would be the reason.
Cheers from the Moose
274063
Follow Up By: KSV. - Wednesday, Nov 28, 2007 at 15:41
Well, idea is – when car going up and down they make no effect, but if car leaning to the side, they get twisted and works like torsion
suspension battling bodyroll. However in harsh terrain they resist to drop one wheel resulting in either body leaning more then it should or wheel gets off the ground.
Sounds like I shall try temporary disconnect one :).
Serg.
537496
