Keep an eye on that spare tyre!. if its not used very often.
Submitted: Wednesday, Nov 28, 2007 at 19:59
ThreadID: 52066 Views:3005 Replies:4 FollowUps:7
Jumped in the 4by this morning, off to work we go!, reversed 4mtrs , what the hell! something not right sure enough ,flat left hand front. Same thing happened about a month ago with a left rear, anyhow the spare was fine last episode, and appeared ok this rouhd , until i got on the freeway and got a bit of pace happening, the vibration in the front was so bad i had to pull over.
On inspection i found two lumps on the inner side wall the size off golf balls, the tyre a michelain 750 x16 would probably be about 4yr old..
Glad i was close to home!
Cheers Axle.
Reply By: Willem - Wednesday, Nov 28, 2007 at 21:05
It only happens to you, Axle......hahhahahahahahhaha!!!
AnswerID: 274123
Follow Up By: Member - Axle - Thursday, Nov 29, 2007 at 06:24
Ya not far wrong Willem !!........lol.
Axle.
FollowupID: 537628
Reply By: Mobi Condo - Wednesday, Nov 28, 2007 at 21:05
One good reason to have 5 wheel rotation for maintenance schedule rather than just the more common 4 wheel rotation!
Cheers - Mobi
AnswerID: 274124
Reply By: stefan P (Penrith NSW) - Wednesday, Nov 28, 2007 at 21:21
Mine Blew out one warm day, while still bolted to the back door! LOL
Cheers Stefan
AnswerID: 274131
Follow Up By: Stephen M (NSW) - Wednesday, Nov 28, 2007 at 22:16
Hi Stefan, bet that scarred the crappa out of you LOL. Regards Steve M
FollowupID: 537589
Follow Up By: stefan P (Penrith NSW) - Wednesday, Nov 28, 2007 at 22:28
It was like "WHAT THE (insert choice four letter word here) WAS THAT!!!!"
Lucky it didn't take the back window with it.
Cheers Stefan
FollowupID: 537590
Follow Up By: Member - Axle - Thursday, Nov 29, 2007 at 06:28
Imagine if you had been standing beside it!!.....lol.
Cheers Axle.
FollowupID: 537630
Follow Up By: Member -Signman - Thursday, Nov 29, 2007 at 08:53
Hey Stefan
Catch ya next Wed evening (5th) ???
FollowupID: 537647
Follow Up By: stefan P (Penrith NSW) - Thursday, Nov 29, 2007 at 15:46
Yep signman, the 5th at 7:30 pm
Cheers Stefan
FollowupID: 537733
Reply By: Wizard1 - Thursday, Nov 29, 2007 at 09:15
I would have thought with the cost of 4WD tryres that most people would be right onto a rotation plan.
Rotation of the spare is more important than a normal car as uneven tread wear on the same axle can cause diff wind up.
AnswerID: 274182
Follow Up By: Member - Jeff H (QLD) - Friday, Nov 30, 2007 at 01:40
Maybe that's another reason for dragging two spares around.
FollowupID: 537888
