UHF Problem
Submitted: Wednesday, Nov 28, 2007 at 23:22
ThreadID: 52081 Views:6843 Replies:4 FollowUps:10
Hi Everyone,
Without getting into a brand debate I have a Uniden UHF and recently it has decided to have no audio. Squelch adjustment produces screen activity as does pressing the button on the mike, but as far as sound goes she is dead. Also the monitor is showing the radio receiving activity.
Have done a basic check of connections etc but haven't been able to work it out.
Anyone out there got any ideas that I should follow up.
Thanks in advance.
Reply By: stocky - Wednesday, Nov 28, 2007 at 23:37
try plugging in an external speaker - my bet the internal speaker is shot - seen a few like it......
AnswerID: 274149
Follow Up By: Blaze - Wednesday, Nov 28, 2007 at 23:43
Ditto Stocky I was about to say exactly the same thing..
FollowupID: 537605
Follow Up By: Brian B (Brisbane) - Wednesday, Nov 28, 2007 at 23:46
OK Guys - Will give that a go.
FollowupID: 537608
Follow Up By: Member - Kiwi Kia - Thursday, Nov 29, 2007 at 07:20
What model ? Do you use a plug in mike/speaker ? It is possible that a headphone jack which normally opens the speaker circuit when used may not be making the speaker circuit.
FollowupID: 537633
Follow Up By: Dave(NSW) - Thursday, Nov 29, 2007 at 14:16
Brian B,
Is it a sundowner module,if so I think ever the volume control or the channel control also if pressed is the Quiet mode check you haven't pressed it accidentally.
cheers Dave...
GU RULES!!
FollowupID: 537707
Follow Up By: stocky - Thursday, Nov 29, 2007 at 14:40
what model radio?
FollowupID: 537719
Follow Up By: Brian B (Brisbane) - Thursday, Nov 29, 2007 at 23:18
Hi Folks,
It is a Uniden UH - 089.
Thought about quiet mode but the manual I have doesn't refer to it.
FollowupID: 537876
Follow Up By: stocky - Friday, Nov 30, 2007 at 06:46
Still bet its the speaker - replaced a few in that model :-)
FollowupID: 537893
Reply By: Member - Mike DID - Thursday, Nov 29, 2007 at 08:28
"Also the monitor is showing the radio receiving activity."
- what does this mean ????
AnswerID: 274171
Follow Up By: stocky - Thursday, Nov 29, 2007 at 08:33
the RX signal strength meter is showing a signal is being received....
FollowupID: 537643
Reply By: traveller2 - Thursday, Nov 29, 2007 at 09:04
Not sure on your radio but I've fixed some that for some weird reason the audio goes through the mike curly cord, when the cord fails the audi went.
I'd go with trying an external speaker first though, I've had more fail that way.
Second problem would be dirt and dust in the volume pot, give it a good squirt of contact cleaner.
AnswerID: 274180
Follow Up By: Brian B (Brisbane) - Thursday, Nov 29, 2007 at 23:21
Ok Thanks. Will give it a go.
FollowupID: 537877
Reply By: Wazza - (Vic) - Thursday, Nov 29, 2007 at 21:01
Dad had similar on his Uniden. It was the microphone. Go to a local Uniden dealer / CB shop (not Dick Smith or Strathfield, but a decent shop) and ask them if you can try a new mic in it to prove your theory. Should not be a drama and around $20-30 for the mic I would guess.
AnswerID: 274287
Thanks.
I have access to another that is working so we will swap the mike and see what happems.
FollowupID: 537878
