GU tail light removal
Submitted: Sunday, Jun 01, 2003 at 17:14
ThreadID: 5215 Views:1889 Replies:3 FollowUps:3
Hi all, I need to remove one of my GU tail light to replace the reverse globe, can someone give me a small hint of how this is achieved. I cant see any obvious way to do so. thanks Michael
Reply By: outtack - Sunday, Jun 01, 2003 at 19:14
pretty sure the gu model only has the 1 reverse light .
AnswerID: 21569
Follow Up By: Michael - Sunday, Jun 01, 2003 at 20:12
Hi there, youre right, its the one thats blown,, Michael
FollowupID: 14074
Reply By: Member - Cocka - Sunday, Jun 01, 2003 at 19:20
Most Gu's only have one reversing light in the LHS. Inside at the rear remove the long thin cover panel. There are a couple of screws/bolts to remove, then easy the whole lamp assembly sideways out of its housing using finger pressure. It may be necesaary to give it a bump with the butt of your hand. good luck.Carpe Diem
AnswerID: 21571
Thank you, i found the screws,
FollowupID: 14073
Reply By: relaxed (Fraser Coast-QLD) - Sunday, Jun 01, 2003 at 22:58
Michael, just be very careful when you bunp it out. You only have the 2 10mm bolts to remove, but the other side is held in by 2 nipple like plugs which are attached to the plastic of the light assembly, they will break easily if your not careful.
AnswerID: 21586
Follow Up By: Michael - Monday, Jun 02, 2003 at 10:27
Thank you, i checked it out with a small torch after removing the bolts so as to see how it was attached, got it out no probs, Thanks again, Regards Michael.
FollowupID: 14093
