hour meter for gernerator
Submitted: Saturday, Dec 01, 2007 at 10:18
Member - lyndon K (SA)
I have a Chrities Charger and wish to get an hour meter so i know when to do oil changes etc. I think i saw a link a here to one in the past but can't find it now.
Thanks Lyndon
Reply By: Ian-Rodeo - Saturday, Dec 01, 2007 at 10:59
Lyndon
Have a look on eBay. They have Hour Meters for Go Carts etc. Suitable for either 2 and 4 Stroke Motors. I have one on the Ride On Lawn Mower. Very easy to install. The wire wraps around the Spark Plug lead. It works fine for me.
Hope this helps.
Ian
274516
Follow Up By: Member - lyndon K (SA) - Saturday, Dec 01, 2007 at 11:07
thanks Ian
538090
Reply By: Member No 1- Saturday, Dec 01, 2007 at 11:31
clean oil is cheap insurance....
an hour meter is no good if you dont run your gennie for months at a time....oils have a high infinity for moisture....moisture,when combined with heat and other impurities in the oil creates acids.......pays to get into a regime of changing oil on a regular basis, rather than on a hour run basis (assumes that you only use your gennie infrequently)
274521
Follow Up By: Member - lyndon K (SA) - Saturday, Dec 01, 2007 at 11:47
Hi, yes know what you mean if not getting used, but about to travel OZ for about a year so it will get used for about an hour a day i guess.
Cheers Lyndon
538101
Follow Up By: disco driver - Saturday, Dec 01, 2007 at 12:16
lyndon,
If that is going to be in fairly constant use why not change the oil on a set day each month (ie approx every 25 hours).
Most small motors have 25 hours as a recommended oil change interval.
Once you are into a routine, it is no problem but carry an empty 5 litre can for used oil disposal.
Disco.
538106
Follow Up By: Member - lyndon K (SA) - Saturday, Dec 01, 2007 at 13:51
Fair call disco, but in my situation if i'm bush camped for a month and it's hot i might run it for 50 hours and if driving a bit and staying in parks for a month ,hardly at all.
Cheers Lyndon
538123
Reply By: Member - 'Lucy' - Saturday, Dec 01, 2007 at 13:44
My lawnmower gets and oil change when ever I remember or feel like it - whether it likes it or not.
274536
Follow Up By: Member - 'Lucy' - Saturday, Dec 01, 2007 at 13:45
Think I might go and change the the oil in Honda 2.0i now though.
538119
Follow Up By: Richard Kovac - Sunday, Dec 02, 2007 at 03:04
My Mower has done 6.6 hours
isant it funny the the keys have moved when you have been drinking LOOlk
538223
Reply By: blue one - Saturday, Dec 01, 2007 at 14:12
NHP sell hour run meters.
36-38
Croydon Rd Keswick SA
5035
PH. 82979055
274540
Follow Up By: Member - lyndon K (SA) - Saturday, Dec 01, 2007 at 14:22
thanks,thats what i wanted! cheers
538129
Reply By: thebigeasy - Saturday, Dec 01, 2007 at 22:28
lyndon Christies do a rev counter/hour meter, check their web site.Very easy to install, supplied wire wraps around spark plug lead.no more guesswork.hope this helps rgds Matt
274605
Reply By: equinox - Saturday, Dec 01, 2007 at 22:50
Try Hinco Instruments
274607
Reply By: Richard Kovac - Sunday, Dec 02, 2007 at 03:00
Lyndon
didn't see the post try this site
Hour meter
274623
