Help! Went 4WDriving today Unseen stick ripped speedo Wiring cable
Submitted: Sunday, Dec 02, 2007 at 21:06
NickDG
Got Home and reconnected cable,an easy soldering job,but speedo and center Diff Lock Light on Dash still not working.Is there some sort of special reset procedure? Vehicle is 2002 105 series Toyota Landcruiser gxl. Thanks in advance. Nick
Reply By: Gob & Denny(hampton park vic) - Sunday, Dec 02, 2007 at 21:10
did ya check all the fuses
steve
274702
Follow Up By: NickDG - Sunday, Dec 02, 2007 at 21:26
No didn't check Fuses! Thats a good thought. Will do. Thanks. Nick.
538332
Reply By: Member - Mike DID - Sunday, Dec 02, 2007 at 21:13
The tension on the wire may have caused a fracture at the ends, as
well as the obvious place where it tore apart.
274703
Follow Up By: NickDG - Sunday, Dec 02, 2007 at 21:34
Yes Mike ,pulled off the covering of the wires up untill where it joined other wiring. All Ok.
538333
Reply By: NickDG - Sunday, Dec 02, 2007 at 23:12
Have now checked both gauges fuses, both ok. None of the other fuse names seem relevant. Any other suggestions anyone?
274724
Follow Up By: Member - Matt (Perth-WA) - Monday, Dec 03, 2007 at 15:12
Nick check all the fuses...sometimes the names are not relevent and use other circuits to operate some funny things.
Isnt there two fuse banks in the cruiser? One up inder the dash as
well and very hard to find?
Matt.
538425
Reply By: Rock Ape - Monday, Dec 03, 2007 at 07:16
The wiring maybe broken inside the insulation and you can't see it.
try opening up the outer insulation and looking/feeling along the inner cores for damage. You could also test from where you repaired to the plugs for continuity.
274733
Reply By: NickDG - Wednesday, Dec 05, 2007 at 15:58
Spot on Matt. checked all other fuses and found one 10Amp one blown,replaced and hey presto all things worked!!Thanks everyone. NickDG.
275130
