saving a route to file
Submitted: Tuesday, Dec 04, 2007 at 15:34
ThreadID: 52229 Views:2314 Replies:2 FollowUps:3
hi out there , i need to know how to save a route to file and be able to open up again i cant seem to open it up again , but i am able to open up my way points no problems with them opening up from there file
i go to the route editor but no route is stored on it
thanks you to any one ............george j wa
Reply By: The Explorer - Tuesday, Dec 04, 2007 at 15:45
Hello - may help if you state what program you are using, OziExplorer (PC or CE), Garmin's Mapsource, Magellan's Mapsend, Trackranger...??
AnswerID: 274974
Follow Up By: Member - George J (WA) - Tuesday, Dec 04, 2007 at 23:08
hi ,
thanks greg for you reply , i have ozi explorer
george.j wa
FollowupID: 538701
Reply By: GerryP - Tuesday, Dec 04, 2007 at 23:47
Hi George,
When you have plotted all your waypoint, open the route editor and construct your route using the listed waypoints. After that, save save both the waypoints and the route files separately. Next time you want to use them, you then need to load the waypoints and route separately as well. Once loaded, you should find the route in the route editor.
Gerry
AnswerID: 275043
Follow Up By: The Explorer - Tuesday, Dec 04, 2007 at 23:55
Yes - the Ozi help file (always a good reference) states
"Loading Routes from File
This is still causing me problems on how to code this properly.
At the moment you should make sure you load the waypoint file which you were using when you created the route. It is not possible to display a route unless the waypoints are loaded as well.
It is possible for the waypoint stored in the route not to agree with the waypoints loaded on the map if the waypoints have been modified since the route was created. This is corrected by pressing the ReLink button on the Route editor"
FollowupID: 538705
Follow Up By: Member - George J (WA) - Wednesday, Dec 05, 2007 at 12:53
thanks to greg and jerry for your help im only new at this so im still stepping my way throuth oz explorer seems quite complex at times
george.j wa
FollowupID: 538786
