Cleaning the canvas on a CT
Submitted: Thursday, Dec 06, 2007 at 10:08
ThreadID: 52288 Views:15008 Replies:6 FollowUps:7
Hi All,
we have had the CT for 2 years now and its starting to look a bit shabby and not sheik.
I know I can not use detergent but can I use a high pressure hose on the canvas with out damaging it? If not what's your best methods
Rgds
Ian
Reply By: gbdid - Thursday, Dec 06, 2007 at 12:06
According to Shannon Lush, Mrs Clean anything from the ABC and spotless book fame say this
Cleaning a mouldy, smelly canvas tent: Set up the tent and let it dry completely. Then make up a saltwater solution with 4 cups of salt to a bucket of very warm water and ½ to 1 teaspoon of oil of cloves. Use a broom to slop the solution on the inside and out. Let this dry and then brush it off with a dry broom. This will remove and kill the mould and help re-waterproof it.
Graham
AnswerID: 275258
Follow Up By: Member - Noldi (WA) - Thursday, Dec 06, 2007 at 12:28
Hi Graham, I will keep that one in mind, its not so much mouldy just the ingrained red dust and bird poo
Thanks for the reply
Ian
FollowupID: 538982
Reply By: Member - John G- Thursday, Dec 06, 2007 at 12:29
G'day Ian
This may not be a lot of help, but the Tvan maintenance instructions for canvas state
"Maintenance of canvas should be to the manufacturer's recommendaitons which are attached to the inside of the tent. We recommend brushing dust and debris off, hose any panels that get stained, and ensuring the canvas is completely dtry before storage of longer than 2 days. Scrubbing or chemicals can reduce water resistance of the fabric"
AnswerID: 275263
Follow Up By: Member - Noldi (WA) - Thursday, Dec 06, 2007 at 13:19
Thanks John,
I have a similar comment on mine but its the dust and crap that seems to get into the weave of the canvas that I was hoping to remove. just using the hose, the water just seems to run right off
Maybe there just signs that it gets used and I have to put up with them.
Rgds
Ian
FollowupID: 538991
Reply By: Truckster (Vic) - Thursday, Dec 06, 2007 at 14:56
Call the manufacturer and ask them. They dont need to know if you got it new or not, and if they ask, yes you did :)
AnswerID: 275279
Follow Up By: Member - Noldi (WA) - Thursday, Dec 06, 2007 at 20:51
Good idea Truck, I did buy it new from them anyway
Ta
Ian
FollowupID: 539073
Reply By: Member - Norm C (QLD) - Thursday, Dec 06, 2007 at 15:22
Ian, it's not easy. Apart from dust, on one trip we came home with a lot of bird and bat droppings on the canvas. I can tell you bat droppings are the pits. Sacrifice your first born before you get them on the canvas!
I used lots of water and elbow grease. Didn't use a high pressure hose, but did use a garden hose with an adjustable garden spray attachment. For the annex, I spread it on the lawn so I could get at it properly. I did scrub, but only with a cloth (part of an old towel). Did not use detergent. After getting most of the stuff off, I got it up over the Hills Hoist (with much cursing) and hosed remaining dust and crap off.
Eventually got enough of it off and with further use in the sun, remaining spots have faded and it is now fine. Just looks lived in, not crappy.
I don't seem to have damaged the water proofing. On our last trip we had plenty of rain and it seemed fine.
AnswerID: 275282
Follow Up By: Member - Noldi (WA) - Thursday, Dec 06, 2007 at 20:58
Thanks Norm, I will have to give it another go, or maybe get the bos to have a go;-)
I'll stay away from the bats
Rgds
Ian
FollowupID: 539078
Follow Up By: Steve - Thursday, Dec 06, 2007 at 22:05
Hey Norm, sounds like the frenzied water assault would've made a good cartoon ;))
If it's cotton canvas it should actually swell the weave, therefore closing it up and making it more waterproof. That's why they tell you to "cure" it. Wet it thouroughly and let it dry before packing away. As for the stains, use your fave stain remover - there are plenty of hints and products around
FollowupID: 539102
Reply By: Member - Au-2 - Thursday, Dec 06, 2007 at 21:10
Just a thought from a token female, I would use a hose-brush that can currently be bought from the dollar shops. It can be connected to a hose or not, but the main advantage is that the bristles are fine and very soft. I use this brush on the vinyl Bar-b-que cover, which comes up shiny again as when new. Most brooms/brushes have very thick and therefore stiff bristles which can't get into the nooks and crannies. Using one of these hose brushes always does a better job than an old 'scrubber.' Good luck.
OzeSheila.
AnswerID: 275350
Follow Up By: Member - Noldi (WA) - Friday, Dec 07, 2007 at 10:48
Thanks Oz sounds like its worth a shot
Rgds
Ian
FollowupID: 539183
Reply By: Member - Paul S (VIC) - Friday, Dec 07, 2007 at 06:25
G'day Ian,
I have had success in removing bat poo by soaking the spot in plain water for half an hour or so and it will then just rinse off. This worked for me after several 40 degree days of baking-on.
Rather difficult to soak a whole CT I know, but take the tension off the canvas roof, make a small cavity by pressing around the area and then pour a puddle.
I would be very cautious about using chemicals, detergents, or hard scrubbing.
Paul
AnswerID: 275415
Follow Up By: Member - Noldi (WA) - Friday, Dec 07, 2007 at 10:49
Thanks Paul,
I'm with you on the chemicals but I will try what you say, nothing to loose
Rgds
Ian
FollowupID: 539185
