New law for Caravan Fridges
Submitted: Friday, Dec 07, 2007 at 14:40
Jimbo - VIC
I was chewing the fat with a bloke at the
Bendigo show who told me that QLD Govt is apparently introducing laws relating to the fitment and efficiency of Van Fridges.
Apparently has to do with the number of people who have suffered food poisoning due to food being stored in fridges that do not keep stuff cold enough.
I have always kept a thermometer in our Van Fridges and know
well that they have gone up to 10 degrees in very hot weather.
The other issue issue that needs to be addressed is the fitting of "ST" climate class fridges. They simply are not up to Australian conditions as they are only rated to operate to 35 degrees (and I reckon that's an overestimate). The most commonly fitted fridge is the Dometic 90L RM 2350, to all makes and types of vans and is rated "ST".
The sooner this is addressed, the better
Reply By: Member - Roachie (SA) - Friday, Dec 07, 2007 at 16:05
That's just another reason why I turfed the 3 way fridge in my camper trailer in favour of an upright Engel 2 way fridge.....good as gold!!!
275510
Follow Up By: Member - Mick M (QLD) - Friday, Dec 07, 2007 at 17:03
roachie the engel, is it the same size as the domestic. what does it run on besides 12 volt p/s how much
mick
539264
Follow Up By: Member - Roachie (SA) - Friday, Dec 07, 2007 at 17:20
G'day Mick,
The one I bought is the same physical size as the Dometic (note: no "S"), but the door does protrude about 10mm further out. It is an 80 litre fridge and works the same as the Engel chest fridges: IE: 240 volt or 12 volt.....and as soon as you plug the 240 volt cord in, it automatically senses the mains voltage and switches over.
Hope this helps,
Roachie
539270
Follow Up By:- Friday, Dec 07, 2007 at 17:54
G'Day Mick and Roachie,
Weaco, Engel and several others make fridges the same size as Dometic 3-way fridges.
Just doing the same as Roachie and tossing the gas fridge out.
Warm scotch on hot days = no
camping fun!
Rolande
539274
Follow Up By: Motherhen - Friday, Dec 07, 2007 at 22:52
Likewise Roachie
When we purchased the previous caravan, we threw out the old 3-way and purchased and Engel upright (around 130 litres) 12/240 volts. An excellent fridge. Not as quiet as the Vtirifrigo we have in the Bushtracker, but acceptable. If it was cool at night, as it often is inland, we'd turn if off at bed time and it held the temperature
539317
Reply By: Member No 1- Friday, Dec 07, 2007 at 22:01
all fridges are rated at a standard ambient of 35c
what must be considered if the fridge can operate effectively in ambients of temps higher than 35....now in
adelaide we rarely experience temps inside the house of higher than 35, so its generally not a problem
if a fridge must work in higher ambients it must have adequate condensing capacity in addition to increased compressor capacity to cope...its some what of a trade off...I am Talking compressor fridges here and not absorption.
the reason they use 35 is so that one can compare electricity consumed to work out the efficiency of a fridge...hence the star rating.......if one (all Manufacturers) were to use a higher ambient say 45c the star ratings would reduce almost proportionally...
275564
Follow Up By: Member No 1- Friday, Dec 07, 2007 at 22:01
airconditioers are the same
539310
Follow Up By: Member No 1- Friday, Dec 07, 2007 at 22:05
pss
forgot to say
absorption type fridges are not as effective as compressor type when ambients are high......
539311
Follow Up By: nowimnumberone - Friday, Dec 07, 2007 at 22:31
son why are you wearing them glasses
i used to have a saying on exploroz about wedding dresses and white goods
ah the wife read it
539315
Follow Up By: Member No 1- Saturday, Dec 08, 2007 at 08:27
i wear them so you dont recoginise me
what was the saying.....did you agree?
539343
Reply By: Ozboc - Saturday, Dec 08, 2007 at 13:58
I actually use 2 fridges - the 3 way fridge in the Jayco - and the Wacco CF80 as storage of food such as meat- with this combination i have no probs staying away for days at a time with 4 kids :)
Boc
275620
