nissan td 4.2 black smoke
Submitted: Sunday, Dec 09, 2007 at 21:09
morrys
hi have this prob and no one can soort it out 109.000kls its on gas ass have extractors k&n air cleaners 68kw at back
wheels on dyno new injectors could it be the pump is anyone out there that can help dont want any smart answers as time is money this is also a auto awaiting some replys regards morry
Reply By: Member - Roachie (SA) - Sunday, Dec 09, 2007 at 21:47
Bit more detail please..............
Do you mean it's a GU 4.2TD with LPG injection?
I would ditch the K&N first up....they are not efficient enough; let too much dust through.
68kw at rear
wheels is dreadful.
Get the thing checked out by a PROPER diesel mechanic; someone who specialises in these matters. Where are you located?
Sounds like pump and/or timing issues.
275846
Reply By: Member - Roachie (SA) - Sunday, Dec 09, 2007 at 21:48
Do you mean it's a GU 4.2TD with LPG injection? Oh, just re-read....you have extractors, so I'm now assuming it's a naturally aspirated model (GQ or series one GU).
68kw at rear
wheels is dreadful.
275847
Follow Up By: morrys - Sunday, Dec 09, 2007 at 23:27
hi yes its a jap import was smocking when i got it so had the following done 1rebuilt injetors 2 extractors with 65mm ex right thru 3 k&n filters 4 auto fully serviced and adjusted 4put it on gas note all these were done on the advise of some very big company names and and no increase in power only a very large hole in pocket just seems dead have turned the gas of and its just the same the injectors were done buy arep company who do earhmoving units plus the dyno it all in all its all failed regards morry
539697
Follow Up By: morrys - Sunday, Dec 09, 2007 at 23:30
i live in
perth
regards morry
539698
Reply By: Member - Geoff C (QLD) - Sunday, Dec 09, 2007 at 22:34
Had the same problem, turned out to have got a tankful of dirty
fuel, changed
fuel filter problem went away. Fortunately there was not much of the
fuel left.
Geoff
275855
Reply By: fisho64 - Monday, Dec 10, 2007 at 01:32
So is it a turbo diesel or does it have extractors?
You cant have both.
275870
Follow Up By: morrys - Monday, Dec 10, 2007 at 21:04
sorry its not a turbo , the problem is that it is a import 1989 and that is the problem cant get anyone to check the throtle control switch as that could cause my problem , not even nissan will not look at it they say that there is no english technical advise available , so thats it getting to hard regards morry
539859
Reply By: CLC50 - Monday, Dec 10, 2007 at 06:34
If Turbo
Check if turbo working Ok
275874
Follow Up By: morrys - Monday, Dec 10, 2007 at 21:10
hi there is no turbo regards morry
539861
Follow Up By: morrys - Monday, Dec 10, 2007 at 21:11
539863
Reply By: Truckster (Vic) - Monday, Dec 10, 2007 at 11:37
would you like to buy some spaces, commas, full stops, and new lines so people can actually read what you write?
275917
Follow Up By: Member - Poppy (QLD) - Monday, Dec 10, 2007 at 14:40
Nownowbrucethatsnotnicelol
539801
Follow Up By: morrys - Monday, Dec 10, 2007 at 20:47
hi a fair comment but no problems seems its just a nack at writing to a computer regards morry
539856
Follow Up By: Member - Lost Dog(WA) - Monday, Dec 10, 2007 at 21:03
Have you tried the EGR valve morry?
Mine was blocked solid open(?) and once clean I got power from somewhere.
Col
539858
Follow Up By: morrys - Monday, Dec 10, 2007 at 21:06
hi thanks will go and check it out ,will post the verdic regards morry
539860
