What size thread (after turbo) ??
Submitted: Monday, Dec 10, 2007 at 12:15
Member -Signman
What size/type thread (more than likely) would the blanking set screw be, in the exhaust pipe on the outlet side of the turbo.
It's a 1hz/ Troopy with after market turbo.
I intend fitting a EGT gauge with a probe adaptor of 1/8 BSP.
Reply By: Wayne (NSW) - Monday, Dec 10, 2007 at 12:25
Signman,
It would more likely be a pipe thread. 1/4" bsp.
A fitting that would be used for air lines on a compressor would fit.
If you have a screw in type air fitting, the one on you air compressor would do.
Try that to make sure that you have the right size and thread.
Once that you have the correct size pop into the hardware
shop and pick up a plug fitting.
Wayne
275921
Follow Up By: Member -Signman - Monday, Dec 10, 2007 at 14:21
Thanks mate..
Yup. you're right. It is 1/4 " - so had to get adaptor to take 1/8 BSP probe. And it cost 60c !!!!!!!!!
539795
Follow Up By: Member - Sam (NSW) - Tuesday, Dec 11, 2007 at 08:07
Where you get the reduciing bush from Signman? I have an EGT gauge to install (autometer), but it has a 1/8 NPT and i need it to go into a 1/4 NPT port on the exhaust.
539910
Follow Up By: Member -Signman - Tuesday, Dec 11, 2007 at 08:30
Hi Sam
Just look up Yellow Pages- Engineering Supplies.
I'm near Camden- and got it from Taylor Engineering Supplies at Narellan.
539913
Follow Up By: Member - MUZBRY (VIC) - Tuesday, Dec 11, 2007 at 09:59
Gay
enzed or pirtec will have that fitting.
539931
Follow Up By: Member - Sam (NSW) - Tuesday, Dec 11, 2007 at 11:10
Thanks folks.
I managed to source some through
Sonsbeek. They already have an order going to a local auto parts place so are just tacking it onto that order for me.
Thanks again!
539943
