TD 200 series LC trailer wiring
Submitted: Wednesday, Dec 12, 2007 at 10:34
ThreadID: 52471 Views:3149 Replies:6 FollowUps:3
We have hooked it all up, put 30amp fuse in towing section.
There is another towing fuse space which we also put another 30amp fuse in.
We have checked the towing fuse in passenger side fuse box (its OK) but still can not get power in 7 pin plug for anything!!!!
Any suggestions would be great???
Bonnidowns
Reply By: Member - Wim (Qld) - Wednesday, Dec 12, 2007 at 11:30
Bonnidowns
First guess would be bad earth connect.
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 276201
Reply By: Bonnidowns - Wednesday, Dec 12, 2007 at 12:11
Checked earth it's not the problem
It's just got no power
Bonnidowns
AnswerID: 276206
Reply By: Gronk - Wednesday, Dec 12, 2007 at 12:14
Is there a wire going to the plug ???
Ring the dealer.....and ask...that's what they're there for !!
AnswerID: 276207
Reply By: Off-track - Wednesday, Dec 12, 2007 at 12:21
In LCOOL forum there is some talk on this. There is a relay in the factory kit.
AnswerID: 276208
Follow Up By: Bonnidowns - Wednesday, Dec 12, 2007 at 13:03
2 questions
Do you have the address of "LCOOL" forum
Do you know where the relay is?
FollowupID: 540120
Follow Up By: Off-track - Wednesday, Dec 12, 2007 at 13:43
www.lcool.org might be handy for you in the future as they have areas dedicated to all Tojo 4WD's. Have to register to view.
FollowupID: 540125
Reply By: Bonnidowns - Wednesday, Dec 12, 2007 at 16:14
Just to add
The LC was wired by Auto elec' it has the loom already installed, problem we are 200ks from him and are trying to find problem without the drive back
AnswerID: 276240
Follow Up By: Wayne (NSW) - Wednesday, Dec 12, 2007 at 18:30
Bonnidowns,
I would be onto the auto electrician to let him know where you are and ask him what time should you expect him to turn up to fix his faulty wiring.
I don't see why you should run after him to fix the wiring that he had not fitted right in the first place.
Wayne
FollowupID: 540161
Reply By: Bonnidowns - Wednesday, Dec 12, 2007 at 21:12
This is what the auto dealer did, in consultation with local dealer. also with limited information from toyota as they themselves know very little, The auto electrician will come to our place but can not predict everything to bring and having country experience it's always better to take it in.
We still feel it's something very simple like a fuse somewhere that we or they have missed
AnswerID: 276305
