Storage setup
Submitted: Monday, Jun 02, 2003 at 22:46
Kevin
I am looking for information on setting up storage, including fridge rollout etc for the back of my Disco Series 11.
Recently met a guy who told me that info is available to purchase aluminium box section and strong roller gear (90cm throw) that will enable construction of light weight but stong storage unit for the 4WD.
Can anyone help with advice re purchase and/or design ideas?
Reply By: Peter - Tuesday, Jun 03, 2003 at 08:01
the product is cubelock and is alloy section. There are two types one square and the other is square with a small lip. There a number of connectors rigat angle T 3 way right angle etc.
Most alloy specilist should have it and it is worth while shopping arround for price.
It is simply a matter of working out what you want and cut and make for rollers there have been several threads in this
forum. Do a search. In those responses there are links to photos and
places to ger gear.
Ours we assembled and then pop rivited one each joint.
Computer rack rollers work really
21689
Follow Up By: Kevin - Tuesday, Jun 03, 2003 at 21:39
Hello Peter,
Thanks for your response. Much appreciated.
Regards,
Kevin.
14205
Reply By: Member - Peter (WA) - Tuesday, Jun 03, 2003 at 09:36
I have some basic drawing on a drawer / fridge system I have made for my 4 runner email me your fax number and I will send them to you if you want
phewitson@westnet.com.auBorn to drive a 4x4 , not a keyboard
York 4x4
21694
Follow Up By: Kevin - Tuesday, Jun 03, 2003 at 21:41
Hi Peter,
Thanks for the response. I believe I now have the link I was told about.
Regards,
Kevin.
14206
Reply By: Truckster (Vic) - Tuesday, Jun 03, 2003 at 10:03
Try this
http://www.geocities.com/hay_dj/Patrol/StorageSystem/PatrolStorageSystem.html
or
http://www.geocities.com/hay_dj/PatrolStorageSystem/PatrolStorageSystem.html
21695
Follow Up By: Kevin - Tuesday, Jun 03, 2003 at 21:42
Thanks Truckster. That's the link I had been told about. Much appreciated.
Regards,
kevin
14207
Follow Up By: Truckster (Vic) - Tuesday, Jun 03, 2003 at 22:37
Glad to help.
There are several people on this and dozens on other forums using Daves plans for rear storage now, its SOoooooo simple Im shocked that these
places can still dare to charge $1000's for rear storage, its obscene....
14213
Reply By: Member - Wherethehellawi - Tuesday, Jun 03, 2003 at 10:34
see post 4939 for major Aus. suppliers on heavy durty slides if you intend making your own. My fridge carrier works a treat.Richard
21696
Reply By: Member - David - Tuesday, Jun 03, 2003 at 11:42
Just a hint for your design. Keep your fridge at floor level. Most of the 'you beaut' units on the market are designed for the slide out to fit on top. If you or your missus are vertically impaired- the top mounted ones are a bitch. At floor level it's much more convenient. This goes for heavier slide out drawers (storage boxes) with your pantry & cooking gear.
Have a look around at a few units- and decide what is wrong with them before you proceed. I spent quite a bit of time thinking before i built
mine- and on trips it works just fine for us- with no reservations.A bad days sailing sure beats a good day at work
21708
Follow Up By: Member - Glenn(VIC) - Tuesday, Jun 03, 2003 at 16:03
I agree with you David,
Unfortunately, when I built
mine I didn't think of that and now I am suffering (being vertically impaired). Difficult to reach the beer at the bootm of the fridge without climbing on the tailgate.Just Do It!
14180
Follow Up By: Ronnie - Tuesday, Jun 03, 2003 at 20:10
I also agree with you David
I am a tad over six foot and have to climb up on the step to to get to the bottom of the fridge
Regards Ronnie
Limmen Bight River July
14197
Reply By: Kevin - Tuesday, Jun 03, 2003 at 16:33
A friend of
mine makes fridge rollers and storage units at resonable prices call Russell on (07) 3886 6843
21736
A friend of
21737
Reply By: Jack - Tuesday, Jun 03, 2003 at 16:47
Queblock's is
http://www.capral.com.au
(Hope I got the link code correct ......).
Jack
21742
