Snatch Strap Repair?
Submitted: Thursday, Dec 13, 2007 at 20:48
BorisK
Hello everyone, I have damaged my brand new ARB snatch strap on its first use. The car I was towing failed to stop in time and the strap got caught under its front wheel and got skidded on. About 1metre from the end is all chewed up. Can straps be resewed and if so who does it around
Geelong?
Merry Christmas
Boris
Reply By: blue one - Thursday, Dec 13, 2007 at 20:53
Time for a new strap.
276499
Follow Up By: Outnabout David (SA) - Thursday, Dec 13, 2007 at 21:44
I think it is time for whovever drove over your strap to buy a new one. The old one is destined for the bin I'M afraid
540400
Reply By: Member - John (Vic) - Thursday, Dec 13, 2007 at 20:54
Sorry to say, Nup!!!
Toss it and get another one.
I would be asking the guy who you used it on to pay for it as its normally the responsibility of the person who needs snatching to use their strap as they don't last that long anyway.
276500
Reply By: Wayne (NSW) - Thursday, Dec 13, 2007 at 20:56
Boris,
That strap has gone to the big bog hole in the sky.
It might be able to repaired but it would be shorter and by the time that is done it would be cheaper to buy a new one.
The driver of the other vehicle should be paying for the new one.
Wayne
276502
Follow Up By: Member - Roachie (SA) - Thursday, Dec 13, 2007 at 21:44
Wot Wayne said!!!!
540401
Follow Up By: Member - Doug T (FNQ) - Friday, Dec 14, 2007 at 01:23
Wayne
The bloke who run over it probably could'nt help running over it , the bloke who owned it should know better than to use a good new strap for tow strap, .....No, I say the owner is at fault and go buy it with his own money.
540447
Reply By: Skippy In The GU - Thursday, Dec 13, 2007 at 20:56
I'd say no but you could ring A noble and sons in
AdelaideNobles & Sons
276503
Follow Up By: BorisK - Thursday, Dec 13, 2007 at 21:03
Skippy Thanks for the link.
540388
Reply By: gottabjoaken - Thursday, Dec 13, 2007 at 20:59
Boris
Oh dear...
"The car I was towing..."
WRONG !!!
you do not tow with a snatch strap. Use a winch strap or much better a cable or chain.
If you were recovering, then the replacement comes as a cost of the recovery.
Who was being recovered ????
Golden Rule... Use their equipment unless it is not in adequate condition, then offer to sell them yours.
Snatch Straps are disposable recovery devices, that should be junked at the first signs of any wear, and especially tear.
Ken
276506
Follow Up By: Hero - Friday, Dec 14, 2007 at 10:19
Ken, Small correction, dont tow with a chain, most are usually only rated to around 2T and will break. Use the strap.
540473
Follow Up By: Member - Kiwi Kia - Friday, Dec 21, 2007 at 12:35
Provideing they are not to long YES tow with a snatch strap - far better then an extension strap - takes the hard jolts out of towing.
Yes you can get snatch straps resown. A local firm where i am at present does it but sorry it's no where near where you are.
541766
Reply By: Truckster (Vic) - Thursday, Dec 13, 2007 at 21:02
3 times now I've stuffed one first use, last time was when using on a club members car when they stuffed up and they still aint replaced it.
Never use your gear on someone elses recovery. If they dont have any, they buy the strap off you before you start.
276510
Reply By: BorisK - Thursday, Dec 13, 2007 at 21:24
Thankyou all, hopefully I'll be a little wiser next time, but thanks to the info link before I've just found a promising listing in the Yellow Pages here in
Geelong. I'll call them tommorow and pass on any new info, if any.
276521
Follow Up By: Member - Franga (QLD) - Thursday, Dec 13, 2007 at 22:47
Hi BorisK,
If you plan on fixing it, cut it short put the same length loop in it and get who ever is going to sew it up to use a Poly Dabond V207 thread (its UV stabilized) with perimeter and diagonal stitching and it will perform just as
well if not better than when original. If not let me know and I'll pay for the freight and fix it and keep it as a spare.
Franga
540422
Reply By: cityslicker - Thursday, Dec 13, 2007 at 21:40
Slightly unrelated, but reading this thread I realised I have a couple of snatch straps in the back of the car that have only been used once in about 5 years.
Do these things deteriorate over time regardless of how often they are used? What do people generally consider the 'shelf life' of these things to be?
276524
Follow Up By: splits - Friday, Dec 14, 2007 at 01:20
I don't know for certain but I would imagine they would have a shelf life. Whether anyone takes any notice of it or not is another matter.
I used to work on ejection seats in the RAAF years ago and all of the webbing had to be replaced at regular intervals.
I once had a Bell motorcycle helmet and the instructions that came with it said the internal padding had to be replaced after a certain number of years because its ability to absorb impacts deteriorated with age and exposure to the sun.
I would say there is a fair chance the same applies to snatch straps.
Brian
540446
Reply By: lifeisgood - Thursday, Dec 13, 2007 at 22:07
My son did the same thing to my strap when he borrowed it to tow someone. He hasnt replaced it of course so I tied a large knot in the end (a Loop) and it will use it for simple tow jobs but not snatching. It makes a rather good tow rope actually ,you just need to keep it of the ground. Chains and cables are horrible things to tow with unless both drivers are experianced in avoiding the jerks. (just waiting for the flak now LOL !)
276530
Follow Up By: splits - Friday, Dec 14, 2007 at 01:31
I worked for a garage many years ago that solved the jerking problem with chains by using an old 10 inch tyre off a Morris 850. They had a short chain that passed through the tyre and attached to the tow bar of the tow vehicle via a large D shackle. The tow chain also passed through the tyre which then acted like a rubber band between the two cars. The little Mini tyre was small enough so as to not hang down and touch the ground when the cars were stopped or the chain went slack. It made towing with a chain a breeze.
Brian
540448
Reply By: Dave B (NSW) - Thursday, Dec 13, 2007 at 22:50
Just get a big Texta and write Tow only on the strap.
Once a snatch strap is used or 'towing', that's all it's good for.
It will have lost it's elasticity.
Dave
276544
Follow Up By: Member - Mike DID - Saturday, Dec 15, 2007 at 12:42
Once you've written on a strap it's a throwaway - the solvents in a Textacolour will damage the fibres by an unknown amount.
540635
Follow Up By: Member - Kiwi Kia - Friday, Dec 21, 2007 at 12:39
Rubbish ! A snatch recovery puts mega amounts more load on a strap then towing and you keep on doing recoveries for years with the same strap. I demonstrate snatch recoveries on training courses and have used the same strap for years. If the strap has been over stretched you will see broken stitching .
541767
Follow Up By: Dave B (NSW) - Friday, Dec 21, 2007 at 22:43
Kiwi Kia, I am only repeating what I have been told by an accredited 4WD trainer (ex police driver trainer)
Davewhen I did my course for business purposes.
I cannot attest to the validity of my previous post apart from that.
My snatch strap is still in it's original package, untouched after many years.
It's just that I try not to put myself in a position to have to use it.
I look for another way around, or ask myself, 'do I really need to go there' and risk getting stuck.
Many times I travel solo, so I use a bit of discretion.
Dave
541882
Reply By: 96 GXL 80 series - Friday, Dec 14, 2007 at 00:08
I think you will find, you are on your own with that one.
You will find that nobody will sew up a
seat belt as they can be held responsible if someone is injured in an accident, and it gets proven that the belt should not have been repaired.
Same with a Snatch Strap, as they are rated as
Another one is that you are not a registered tow vehicle and you would be responsible for any damage to the other vehicle or it's passengers if injured due to your recovery.
Check with your insurer as I did.
276557
Reply By: Member - Bucky (VIC) - Friday, Dec 14, 2007 at 07:12
Boris
Why take the chance, could cost you dearly ! ( danger there )
Just bite the bullet, and get another strap.
It ain't worth the risk.
Bucky
276568
Reply By: stevesub - Friday, Dec 14, 2007 at 07:25
Keep the old strap and use it for towing ONLY. Buy a new one for snatching. That is what I have done with my 2 old snatch slightly damaged straps for towing only - one for each vehicle. Both vehicles also have new virgin snatch straps for snatching.
Stevesub
276571
Reply By: Dave from P7OFFROAD Accredited Driver Training - Friday, Dec 14, 2007 at 08:59
Wow! Unanimous points decision!
Yep, bin it!
I always carry a new strap (wrapped in plastic) for just such an occasion!
BTW, go look for "Just Straps" straps, nothing flash, but excellent quality at half the price of the ARB!
276596
Follow Up By: wigger - Friday, Dec 14, 2007 at 15:12
Dave
Have been looking at getting one of those double ended winching straps from 'Just Straps' and the blurb says 'a protective webbing is supplied and should be placed in the eye of the connecting strap to reduce wear' If your other strap has a hook on the end and you put the winching strap through it, won't it end up crushing or bunching up the winch strap at that point. I thought the idea was to always keep straps flat.
540521
Reply By: Member -Dodger - Friday, Dec 14, 2007 at 17:23
Don't ditch the strap as they make great swings for kids when attached to a tree when
camping and do not damage the tree.
276668
Follow Up By: johannagoanna - Friday, Dec 14, 2007 at 21:51
Oh man, I love that idea
Just make sure you write on it that it is stuffed, so someone doesn't tyr and use it!
Jo!
540574
Reply By: Member - Brian H (QLD) - Friday, Dec 21, 2007 at 15:32
Agree ditch the strap and use as a swing ............ $80.00 bucks is cheap investment in a strap when you consider what can happen if things go pear shaped if it breaks under load.
Brian
277850
