Battery light on dash
Submitted: Saturday, Dec 15, 2007 at 08:20
giffo
I have just got a GU Patrol 2.8 TD and noticed the battery symbol on the dash is lit up slightly.does this mean that the alternator is not working properly.
Reply By: Wayne (NSW) - Saturday, Dec 15, 2007 at 08:36
Giffo,
If the battery light is on but not very
bright it could be a bad earth problem.
Made sure that all the earth leads are clean and tight on the battery and the body. There should also be a good earth to the motor as
If you have a multi meter you could check how many volts the alternator is pumping out.
However if all this is OK it sounds like a trip to the local auto electrician.
Wayne
276747
Reply By: Bonz (Vic) - Saturday, Dec 15, 2007 at 10:12
Im my experience these are quite difficult to track down.
I have gone down the path of trying o find where the bad earth is, and have ended up adding extra earth straps battery to motor, battery to body and motor to body.
I found that fixed the problem.
276756
Reply By: Member - Uncle (NSW) - Saturday, Dec 15, 2007 at 17:18
Sounds like the brushes in the alternator could be on the way out also.
276793
Reply By: stefan P (Penrith NSW) - Saturday, Dec 15, 2007 at 17:34
Stress less :) My 2.8 has done it for the 1.5 years I have owned it.
Both Batteries charge fine.
Cheers Stefan
276797
