GU Flare repairs
Submitted: Tuesday, Dec 18, 2007 at 20:18
Leroy
Hi Guys,
There was an incindent that resulted in the rear door flare coming off and the rear body flare partly removed!
I tried to pull the rest of the flare off without breaking any plastic clips etc. It is virtually impossible to pull the flares off without breaking any clips or plastic tabs/brackets on the flares.
Now what should I glue that tabs/brackets back on to the flares with?
Hot glue gun, liquid nails? Anyone got the best solution?
Thanks......Leroy
Reply By: Martyn (WA) - Tuesday, Dec 18, 2007 at 20:54
Leroy,
I did the same, I bought replacement clips from Nissan they weren't as expensive as I thought they would be. Nissan sell the clips as a regular item they're used to this sort of thing. Make sure you keep the rubber seal you can't get them any more. Hope this helps.
277335
Follow Up By: Leroy - Tuesday, Dec 18, 2007 at 20:59
not just the little white clips/posts broke but also the brackets/tabs that are moulded to the flare that these little clips go into.
Leroy
541243
Follow Up By: Member - joc45 (WA) - Tuesday, Dec 18, 2007 at 22:22
I had the same problem. The plastic is polypropylene, and is not easily glued or welded. I managed to find a plastic repair place which fixed the tabs for about $20, which was better than the $360 Nissan wanted. They lasted a couple of years before one came loose again. I managed to make a small metal L-bracket which I fitted inside the flare and screwed it to the door.
Do a Google on welding polypropylene.
Gerry
541295
Reply By: Member - Luke (SA) - Tuesday, Dec 18, 2007 at 20:55
I would try Locktite 401 super glue. Sounds a little weak but trust me this stuff is worth its weight in gold as far as super glue is concerned.
Cheers Luke
277336
Reply By: Bonz (Vic) - Tuesday, Dec 18, 2007 at 21:56
Dont even ASK what the replacement cost of one of those suckers is. I had all replaced down the passengers side and near cacked when they told me the cost. WOWOWOW Overpriced plastic I say
277353
Reply By: Member - Beatit (QLD) - Wednesday, Dec 19, 2007 at 09:16
The replacement clips were cheap enough. I used silastic for the broken bolt clip on the bottom - this has been in place for a couple of years. I have lost the rubber but it doesn't look so bad without the rubber.
Kind regards
277386
