Kamar rear bar
Submitted: Friday, Dec 21, 2007 at 19:23
ThreadID: 52748 Views:4213 Replies:3 FollowUps:11
Evening all,
I have a Kamar bar on my Patrol which was on it when I bought it.
But it is the standard bar with out the bits at the end to put wheel carriers on it.
Has anybody here modified a stardard bar before? I think it would be possible for a metal fabricator to drill holes and weld some pipe in??
Other wise I am just lugging the heavy steel bar around for nothing.
Kamar were no help, they only wanted to sell me a new bar.
Cheers Stefan
Reply By: Wayne (NSW) - Friday, Dec 21, 2007 at 19:36
stefan,
It can and I can do it.
Not that hard.
Wayne
AnswerID: 277883
Follow Up By: stefan P (Penrith NSW) - Friday, Dec 21, 2007 at 22:35
As per follow up 3 to reply 2....aren't experiments FREE!! LOL
FollowupID: 541881
Follow Up By: Wayne (NSW) - Saturday, Dec 22, 2007 at 07:03
stefan,
It is not exactly an experiment. I think that they call it R&D, and you know how much that cost.
MM me
Wayne
FollowupID: 541897
Reply By: Andrew from Vivid Adventures - Friday, Dec 21, 2007 at 19:39
The wheel carriers are on axle stubs I think...
AnswerID: 277884
Follow Up By: Wayne (NSW) - Friday, Dec 21, 2007 at 19:46
Andrew,
Now you have told him how to do the modification.
Wayne
FollowupID: 541838
Follow Up By: Andrew from Vivid Adventures - Friday, Dec 21, 2007 at 20:01
Yeah, well I didn't see your response when I entered mine... sorry to do you outa buziness.
See you in the bush
Andrew.
FollowupID: 541846
Follow Up By: Wayne (NSW) - Friday, Dec 21, 2007 at 20:10
Andrew,
Not doing me out of business yet. :-))
I made the modification to the rear bar that I had on the 80Series. Converted a single to a dual wheel carrier.
With the Troopie I made the rear bar and dual wheel carrier. I am thinking about doing this a side line and Stefan's vehicle would be good to experiment on. It is a Nissan after all and I could not make it any worse off. :-))
Wayne
FollowupID: 541847
Follow Up By: KiwiAngler - Friday, Dec 21, 2007 at 20:20
Wayne
You are a BAD man :-) :-)
Merry Xmas mate
FollowupID: 541850
Follow Up By: stefan P (Penrith NSW) - Friday, Dec 21, 2007 at 22:33
We will have to talk Wayne :)
Cheers Stefan
FollowupID: 541879
Reply By: Member - Glenn D (NSW) - Friday, Dec 21, 2007 at 20:21
There is a caravan supply / camping store near me and they have a wide range of stub axels.
I am lead to believe the Kamar ones use HQ Holden ones? but if you are going down this road you woud probably be wanting to build your own swing arms , just got a quote for OL ones at $700 each ( I only know this cause I have just been out bid on an OL rear bar on eBay , was $460 all week and I got outbid by $10 in the last 5sec , damn Austion Sniper! bar new is $1700 )
Like they said gat stub axels welded in and you are good to go.
Glenn.
AnswerID: 277885
Follow Up By: Peter 2 - Friday, Dec 21, 2007 at 22:24
Getting stub axles is the easy part, sourcing the hub to weld the arm to is very hard. You can't use a trailer hub as they are too big and are cast which makes them hard to weld to.
I managed to buy one and then had a machinist make me up some more. From memory I had to get ten made to get the cost down to something reasonable.
Basically you need a 75mm diameter piece of mild steel with the centre machined the same as a trailer hub to take the bearings, seal and cap.
FollowupID: 541878
Follow Up By: Member - Glenn D (NSW) - Saturday, Dec 22, 2007 at 21:12
Still alot less than $700 each , then you just weld up your own arms !
Glenn.
FollowupID: 542007
Follow Up By: Wayne (NSW) - Saturday, Dec 22, 2007 at 21:33
Glenn,
I have had weld splatter go down the inside of my boots and that really hurts.
Welding you own arms would have to bring a tear to your eye. :-))
Wayne
FollowupID: 542011
Follow Up By: Member - Glenn D (NSW) - Saturday, Dec 22, 2007 at 21:42
Just as long as I have a straw for my beer I will be OK.
FollowupID: 542015
