Monday, Dec 24, 2007 at 23:27
Eric, It is true that the pump works for a short time every time you start the motor. If you doubt this, try opening the
fuel filler door and remove the main
tank's cap. Standing outside the vehicle, start it up and move to the filler's hole......you will witness the
fuel being pumped into
the neck of the main
tank, as it happens right up near the top of
the neck.
Also, my advice to all Patrol owners is to keep the main
tank full (or close to full) all the time. This will ensure the pump has some
fuel to "work" on all the time. These pumps are very expensive and if you leave the sub
tank empty the pump will stuff up in a short period of time.
Also, keeping both your tanks full as much as possible will avoid (or lessen) the liklihood of algae forming in either of the tanks.
Roachie
542364
