93 Pathfinder front suspension.
Submitted: Monday, Dec 24, 2007 at 22:39
mrgherkins
Does anyone know how high can the 93 Pathfinder WD21 front
suspension (Torsion bars) can be raised before causing damage
to front end eg: CV's,steering,ball joints,etc....
I raised the rear with 40mm raised Pedders springs. I would like to raise the front to get the correct rake. Does anyone know what the standard rake is?
Reply By: F4Phantom - Monday, Dec 24, 2007 at 22:50
I had a navara I did it too (same car). I wound it all the way to the top bump stop to equalise/level the height after re-indexing the bars. Then I backed off to 3/4 height on the passenger and just under the bump stop for the driver, over a week the both setteled to just over half way which is good as above that your cvs wear fast and you use more
fuel.
278332
Follow Up By: mrgherkins - Tuesday, Dec 25, 2007 at 11:04
Thanks F4Phantom.
542394
Reply By: johannagoanna - Tuesday, Dec 25, 2007 at 19:55
Come and join us here!
www.pcoa.org.au/
forum
Lots of knowledge around about the Pathfinders. Someone will know the answer for sure.
Jo
278387
Reply By: mrgherkins - Wednesday, Dec 26, 2007 at 11:51
278450
