changing fuel tank?
Submitted: Friday, Dec 28, 2007 at 10:05
ThreadID: 52906 Views:1975 Replies:3 FollowUps:0
just put a stick up through my tank out at a mates place.i know need to change it out it belongs in a triton mk double cab diesel.
anyone got hints and helpful ideas.
Reply By: Member - Graham H (QLD) - Friday, Dec 28, 2007 at 20:31
The nearest wrecker maybe or perhaps a good welder can repair it
AnswerID: 278802
Reply By: Gerhardp1 - Friday, Dec 28, 2007 at 20:52
Find a welder to repair it, and maybe consider putting a drain plug where the hole is so you can drain it in future. A wrecker should have a few old engine sumps that you can cut a suitable piece out of complete with sump plug.
Any muffler shop welder should be able to handle the job.
Obviously the tank needs to be removed from the vehicle filled with water while this is done :)
Or replace it with a long range tank ?
AnswerID: 278807
Reply By: mechpete - Sunday, Dec 30, 2007 at 18:24
If its a standard tin tank , solder a patch over the hole ,
it will be ok
mechpete
AnswerID: 278993
