puncture repair in a bottle
Submitted: Friday, Dec 28, 2007 at 15:23
ThreadID: 52918 Views:4833 Replies:4 FollowUps:3
Has anyone used the liquid puncture repair in a bottle products. I believe the liquid is squirted into the tube and the tyre then inflated. If the tyre is punctured, the sealant leaks through the hole where it meets the air and hardens. I'm not keen on using this in a car but wonder if it would be a good product for the kids bikes which suffer from prickle enduced punctures at a local caravan park.
thanks Kc
Reply By: Member - Andrew (QLD) - Friday, Dec 28, 2007 at 15:43
Check out this thread from a couple of days ago ==> http://www.exploroz.com/Forum/Topic/52825/Those_aerosol_tyre_repairinflater_thingies.aspx
Andrew
AnswerID: 278749
Follow Up By: Member - Andrew (QLD) - Friday, Dec 28, 2007 at 15:58
As a followup, i use Stan's NoTubes on my mountain bike with great success, though there is a home-made recipe for a similiar product that works great.....
Andrew
FollowupID: 542800
Reply By: kcandco - Friday, Dec 28, 2007 at 16:10
Hi Guys
Stans and Slime seem to be the main contenders. Any suggestions where to buy them and cost?
Thanks for your help. I have used the puncture repair in a can but found they gum up the valve in the long run.
regards Kc
AnswerID: 278751
Follow Up By: Member - Andrew (QLD) - Friday, Dec 28, 2007 at 16:27
Almost any bicycle shop should stock one or the other. :-) Stan's (no-tube system) is not cheap though, and the kits are tailored for one bike only......need to purchase extra rim tapes etc for more than one bike. Slime has similiar issues.
Andrew
FollowupID: 542802
Follow Up By: Gerhardp1 - Friday, Dec 28, 2007 at 20:45
Slime is available from Repco in at least 3 different sizes.
They may gum up the valve in the long run, but if it gets you home from the middle of the desert, a new valve is not going to break the bank.
Slime does not require rim tapes for cars, not sure about bikes.
FollowupID: 542859
Reply By: DesF - Friday, Dec 28, 2007 at 17:32
Slime is great for pushy's , and it seals motor cycle tubes as well, if it is a big hole it makes a mess and sticks the tube to the tyre, but you cant have it both ways.
cheers Des.
AnswerID: 278763
Reply By: Member - Willie , Epping .Syd. - Friday, Dec 28, 2007 at 19:26
Would these things be a good thing to put in the small tyre on my jockey wheel ?
It has not gone down yet , but I thought it might extend it's life .
Thanks ,
Willie
AnswerID: 278786
