wheel size
Submitted: Sunday, Jan 06, 2008 at 18:50
Member - JASON M (QLD)
can any1 help me.ive got a 2002 hilux and ive put on 15" sunnies on it,ive also got a 2002 prado with alloys standard 16".i use the pardo when the misses an i head on our trips an use my lux 4the boys trip aswell as my work truck.
question im thinkn bout doin an please say if not good idea as im due 4new tyres on the lux an keepn all tyres an rims same size putn 16"bak on the lux but alloys so can use them 4a 2nd spare on the prado an reverse
im thinkn of buyn sum late model lux rims off the sr5.need2 know if they will fit the lux an prado as of offset an stud pattern same etc.cheers and thankis 4all ya value info every1 has out there
Reply By: Member -Signman - Sunday, Jan 06, 2008 at 19:17
Check out the ROH website- they have a fitting guide with offsets/PCD etc.
Maybe help 2 U
280119
Reply By: barney rubble - Sunday, Jan 06, 2008 at 19:19
Gday jas not sure if its relevant to your but we found out the hard way at work recently after 05 the hilux req a diffrent rim offset known as a 30p offset but fairly sure the earlier prados/hilux should rims should be the same
and havin all your rims the same makes good sense to me
barn
280120
Follow Up By: traveln - Tuesday, Jan 08, 2008 at 10:28
thanks 4the info guys.may u hav the best yr an put plenty of
miles on the clock.will let u know wat i find an end up doin cheers
544665
