diesel/gas patrol 4.2
Submitted: Tuesday, Jan 22, 2008 at 16:23
ThreadID: 53789 Views:3128 Replies:3 FollowUps:4
to all 4.2ltr patrol owners that have taken the plunge & had gas
fitted are you happy with the out come & how many klms have been clocked up so far without incedent .is it worth the money &
what system is the best to get fitted & where in vic can you get it done.
is there any chance of engnie failure due the gas drying out
valves ,heads & so on. even though it doesnt run soley on gas wont the gas going through the injectors & were ever else it goes dry out what the diesel normaly lubricats
Reply By: CraigB - Tuesday, Jan 22, 2008 at 18:00
Hi pjd,
Try Parnell in Vic.
They are the top of the line (as in most expensive) but IMO also the best system.
CraigB
ps. no affiliation .. just a happy customer.
AnswerID: 283156
Follow Up By: Geepeem - Tuesday, Jan 22, 2008 at 19:50
HI Craig,
I am looking into a system but live in Queensland so I can't go to Parnell (whereever that is).
Are you able to tell me the brand name of your system?
If you don;t want to post it on here can you email me?
havilahheights@aapt.net.au
Is it a pre or post turbo injection system?
Is it computer controlled (electronic) or mechanical injection (based on turbo boost)?
It is very difficult to get a comparison of different types of systems.
So your experience is quite valuable to someone researching it,
Thanks,
Cgheers,
Glen
FollowupID: 547764
Follow Up By: CraigB - Tuesday, Jan 22, 2008 at 19:59
Sorry I must have misunderstood you. I though you asked where in Vic.. I thought you meant Victoria. Anyway Parnell are nationwide but are based in Laverton. Check their site LPG Gas
CRaigB
FollowupID: 547765
Follow Up By: Geepeem - Tuesday, Jan 22, 2008 at 20:17
Thanks I am just cashing in on the post. I did not post the original question.
Thanks, I will look up the Parnell web site
Glen
FollowupID: 547772
Reply By: Nav 8 - Tuesday, Jan 22, 2008 at 19:30
pjd,, The gas does not go through the injectors, it is injected into the air intake. No it will not dry anything out, it simply helps the diesel fuel to burn more efficiently resulting in more power and a better fuel consumption. You will be happy with it I am sure... Regards Nav.
AnswerID: 283165
Reply By: 1arm - Tuesday, Jan 22, 2008 at 22:22
Pjd
A guy I work with has a gas system fitted to his 4.2lt patrol. Talking about it last night he said it dosent do much for city driving but for the runs he does from Perth to Albany and Esperence and also up north it makes a difference in both economy and power. He was recommending it to another workmate but was saying he would only have it done if he was holding onto the venicle for a few more years.
Overall he was happy he had had it done. Not sure how many kms he has done but has had it fitted over a year ago.
Evan
AnswerID: 283213
Follow Up By: pjd - Wednesday, Jan 23, 2008 at 12:09
hi 1arm what does your mate think of gas when off road
does it make much difference then or is it much like city driving
FollowupID: 547905
