285/70/17 bfg a/t on prado 120 series
Submitted: Sunday, Jan 27, 2008 at 22:14
Member - Josh B (NSW)
has anyone fitted 285/70/17 bfg a/t on 03 or later model prado.? do they hit the upper control arms? or should i just be happy with the 265-70-17? thanks
Reply By: leachy_9 - Sunday, Jan 27, 2008 at 22:55
Josh,
To fit 285/70/17 without rubbing you will need at least 50mm of lift and P50 offset
wheels (Prado standard
wheels are P30).
leachy.
283998
Follow Up By: Member - Josh B (NSW) - Sunday, Jan 27, 2008 at 23:10
thanks leachy, my prado has pedders 2" spring lift but standard shocks and struts by the look of it. also has standard gxl alloys i think they are 7.5" wide? what type of wheel has p50 offset? would the smaller 265 still fit?
548714
Follow Up By: leachy_9 - Monday, Jan 28, 2008 at 09:45
Josh,
265/70/17 will fit on your
wheels with no rubbing issues (that's what I run). I don't know what
wheels come standard with P50 offset, the people I know that have done that have used after market
wheels. The best guys to speak to are
ATS in
Geelong.
They are the gurus on 120 Prado
suspension and
wheels.
Leachy
548767
Reply By: GO_OFFROAD - Monday, Jan 28, 2008 at 19:00
ATS Daz here, you can fit 285's, but they take some trimming, to fit.
Did one last week.
need to plasma cut the body mount, trim the mudflap, and make some room behind it.
Have also done some with 33 x 12.5's and 34 x 10.5 swampers.
284168
Follow Up By: Member - Josh B (NSW) - Monday, Jan 28, 2008 at 22:15
thanks daz,i emailed you guys at ats with more or less the same question. when you say cut the body mount is that the one that is front of the wheel (looks like the rad support mount?) or the cab mount with the mud flap and inner gaurd in front of it? how close to the top control arm does the tyre come? did you take any pics? if you did any chance of emailing them? thanks for the post.
548967
Follow Up By: GO_OFFROAD - Tuesday, Jan 29, 2008 at 20:01
the one behind the mud flap.
dont have pics.
549122
