Voltage Reg or Alternator??
Submitted: Wednesday, Jan 30, 2008 at 21:14
ThreadID: 54054 Views:2676 Replies:3 FollowUps:0
Running a 60 Series, twin batteries - 1 x crank and 1x fridge only (50 L Trailblaza)
Digital voltage readouts on both batteries - within 0.1V of multimeter on either battery comparo dig readout.
Digital sets off alarm at 15.5 (+/- 0.2 V)
Is Alternator problem or Voltage regulator - intermittent and call into lecky - no problem - bluudy Murphy.
Advice please.
Ta
C
Reply By: Eric Experience - Wednesday, Jan 30, 2008 at 21:46
Chriscd.
The problem is the regulator or the wire that supplies the reference voltage to it. Have you had a so-called smart regulator fitted? some of these interfere with the regulator. Eric
AnswerID: 284611
Reply By: Member - Doug T (FNQ) - Wednesday, Jan 30, 2008 at 22:01
Is it overcharging the batteries, ie is one of them getting over cooked, if it is the Alternator ...if it's like the 75 series wiring it should have a white wire coming from the plug at the rear of the alternator, closest to the engine block ,Cut it about 120mm back , fit a terminal and fix it to the main live terminal on top of the alternator, tape up the end from the firewall.
THIS WILL ONLY APPLY TO HEAVEY DUTY ALTERNATERS 130AMP.
AnswerID: 284619
Reply By: Chriscd - Thursday, Jan 31, 2008 at 12:27
Thanks Guys,
Will check out both options - re cooking batteries - replaced cranking approx 2 months back following 3 years service, replaced aux appox 1 week back after 2+ years in tropics, had digital fitted approx 18 months back and has been intermittent increases in last 12 months or so.
Ta
C
AnswerID: 284699
