12v relay
Submitted: Friday, Feb 01, 2008 at 18:51
samsgoneagain
does anyone know the minimum volts to activate a 12volt relay. is it like 10 volts or 9 volts or 5 . thanks . and good on ya !!
Reply By: Robin Miller - Friday, Feb 01, 2008 at 18:52
Typically closer to 9v Sam , but after its made contact it won't release until around 5v
284973
Reply By: Derek from Affordable Batteries & Radiators - Friday, Feb 01, 2008 at 19:14
Hi Sam
Ours switch on at 7.1V and off at 4.1V
They are 12V 30A 5 pin
Derek.
284974
Reply By: Mike Harding - Friday, Feb 01, 2008 at 19:19
What are you trying to do with it Sam?
The "pull in" and "drop out" voltages vary amongst manufacturers and models.
Mike Harding
284977
Follow Up By: samsgoneagain - Friday, Feb 01, 2008 at 19:33
oh.. i was going to put it from the second battery to the fridge so when the voltage drops too low the relay would cut out and stop draining the battery. like a cheap voltage drain switch thing i suppose..
549765
Follow Up By: Mike Harding - Friday, Feb 01, 2008 at 20:04
Nice idea Sam but it won't work I'm afraid.
By the time most 12V relays reached the "drop out" voltage the battery would be
well below its minimum voltage. Take a look at some of the electronic cut-out devices available; they are not too expensive.
Mike Harding
549771
Follow Up By: samsgoneagain - Friday, Feb 01, 2008 at 20:12
ok, thanks mike and co.
549777
Reply By: Derek from Affordable Batteries & Radiators - Friday, Feb 01, 2008 at 20:18
Why don't you use a proper cut out.
Derek
284984
Follow Up By: Mike Harding - Friday, Feb 01, 2008 at 20:41
Even better... I think Derek will be able to sell one to you!
549782
Follow Up By: V8 Troopie - Friday, Feb 01, 2008 at 23:08
That one switches off at 11.2V. This is a bit too low IMO to save a battery.
The gadget has an English front panel but the important details on the back are in German!
Abschaltspannung = switch off voltage
Einschaltspannung = switch on voltage
Max. Stromaufname = power rating
Klaus
549829
Follow Up By: Ray - Saturday, Feb 02, 2008 at 08:09
I baught one off Derick. Cheap and works fine. I just fitted an aderson plug to match my fridge
549856
