12v Pressure washer
Submitted: Saturday, Feb 02, 2008 at 14:25
Mark
http://www.carcube.com.au/
Just wondered if anyone had tried one of these & how they compare to normal pressure washers, 130 psi sounds resonable for 12v. It says this on the website about using during
water restrictions;
If you are allowed to use tap
water to wash your car you can use Car Cube. At 07/5/07 this included
Sydney,
Adelaide,
Perth,
Darwin and
Hobart. Remember, an average bucket wash takes between 4-11 buckets of
water. Car Cube only uses 2.
At 7/5/07
water authorities in capital cities around Australia advise that people can wash a car with
tank water from rain fall. Every authority we spoke to said your
tank water can be used however you want to use it. We recommend you wash a car with Car Cube® and not your hose. An average hose wash will use 18 buckets or more – Car Cube only uses 2. Protect our planet – limit your
water usage..
Reply By: Mark - Saturday, Feb 02, 2008 at 17:50
Well curiosity got the better of me & I went out and picked one up from the local M/C dealer. Verdict ...
well its certainly not a replacement for a mains pressure & a 130psi equates to around 9 bar & my mains pressure washer is 100 bar so thats around 10% of the power. It has it use's though & I found it handy for cleaning around the inside of the door seals on the 4x4 as the low volume of
water means you can get into those tricky spots without dreanching the inside of the vehicle. I think it will be useful on a
camping trip for cleaning the dust off the back of a vehicle etc, also good for engine bays & motorcycles where a higher pressure washer can push dirt behind oil seals.
Says in the manual that you should only put cold
water in but the blokes at the M/C
shop reckon they put warm
water in & use them as shower after a day of dirt bike riding, could be handy on
Stockton beach for a quick rinse at the end of the day & same goes for the surf rods & reels.
Well I'm sounding like a salesman, simple setup though with a marine type pump & pressure switch, wish i'd of though of it though as the bike
shop said they are selling quite a few, story of my life.......
285163
Reply By: Member - Mike DID - Saturday, Feb 02, 2008 at 23:02
I bought a normal pressure washer for $79 and connected it to
tank water - if I want to run it off 12 volt I'll use my Inverter.
285227
