Quick question.What size socket GQ front bearings
Submitted: Friday, Feb 08, 2008 at 20:04
ThreadID: 54375 Views:2379 Replies:3 FollowUps:5
Hi all.
The rain has let up on the Gold Coast which has given me a chance to finaly repack (or maybe replace) the front wheel bearings on the GQ. I have done a quick search through the archives but i cant find what size socket i need to do the bearing nut and locknut. I think it is 54mm can someone let me know as i need to buy one in the morning.
Thanks heaps
Steve
Reply By: al - Friday, Feb 08, 2008 at 20:10
52mm
regards
al
AnswerID: 286425
Follow Up By: Member - steve H (QLD) - Friday, Feb 08, 2008 at 20:12
Thank you al
I will get one in the morning
Steve
FollowupID: 551550
Reply By: Member - DAZA (QLD) - Friday, Feb 08, 2008 at 20:33
Hi Steve
While you are at it, you can wash your truck, the Water Commission
has lifted the ban on hoseing, until the Hinze Dam stops over flowing,
no restrictions for a few weeks, on the Gold Coast.
Daza
AnswerID: 286430
Follow Up By: Member - steve H (QLD) - Friday, Feb 08, 2008 at 20:39
I done that a couple of weeks ago when they gave us a wet weekend. I washed 3 cars,our two story house,all the paths,my sons motor bikes,the letter box,the wife,the kids,the cat,and anything else i could find. Now i am waiting for the excess water bill.
Steve
FollowupID: 551558
Reply By: Member - Duncs - Saturday, Feb 09, 2008 at 15:46
Steve,
I found buying one to be a very expensive option, and it wass not all that easy to find a shop that had one.
I made one out of a piece of flat bar, I think it was about 5 x 45mm
I took the nut off and clamped the nut inf a vice with the flat bar and simply bent the bar around the nut. I welded the joint, welded a piece of the flat bar across the end and welded a large nut, mine was 19mm, but whatever you have would do the job. Just make you sure you have a socket to fit the nut you use.
Have been using it for years and it is still going strong. It was a lot cheaper than the shop bought alternative, I had all the stuff lying around the shed, and I get great saticfaction out of lending to the mates from time to time.
Duncs
AnswerID: 286553
Follow Up By: Stu050 - Saturday, Feb 09, 2008 at 23:13
Got one from a local 4wd shop up here for $19 off the shelf.
FollowupID: 551813
Follow Up By: Member - Lionel A (WA) - Sunday, Feb 10, 2008 at 07:54
Stu....M-M-Mate !
Who's the shop
Where's up here
Will they post one to WA.
Cheers....Lionel.
FollowupID: 551844
Follow Up By: Stu050 - Monday, Feb 11, 2008 at 15:12
Lionel,
The shop is Lunds 4wd spares in Cairns (up here)
they are at 74 Ishmael Rd, Earlville.
Phone (07) 4054 1777
Give them a call and see what they can work out.
Stu
FollowupID: 552109
