vice on bull bar
Submitted: Sunday, Feb 17, 2008 at 19:17
Member - lyndon K (SA)
Does anyone know if there is a commercially made vice that is designed to fit a bull bar? Don't want anything to HUGE.
Lyndon
Reply By: Member - Jack - Sunday, Feb 17, 2008 at 19:37
Lyndon:
Have not seen one on a bullbar, but was impressed with one I saw which fitted into the slot on a tow bar. Just a normal vice welded onto a bit of square tubing, drilled to take the retaining pin. Worked a treat for the owner. He would just remove it when not in use.
Might be another option to consider.
Jack
287994
Reply By: fozzy - Sunday, Feb 17, 2008 at 19:38
Lyndon
just work out where on the bull bar one will fit and purchase one to suit-drill holes and bolt it on.
Would recommend you put one on a rear bar so you dont contravene any possible laws covering protrusions etc.
have seen plenty on rear bars but none on bull bars.
cheers fozzy
287995
Reply By: V8Diesel - Sunday, Feb 17, 2008 at 19:48
I bought a swivel 'scaff clamp' (for builder's scaffolding) and ground the centre pin out which left me with 2 seprerate clamps. Get a couple of half inch bolts, grind the heads down to suit the hole and weld them to the clamp then bolt this to your vice.
This is rock solid and takes 30 seconds to fit to a standard bullbar. When not in use just undo the two nuts with a shifter and throw it in the back.
100% legal and 100% solid. Easy!
287999
Reply By: Member - Doug T (FNQ) - Sunday, Feb 17, 2008 at 20:12
lyndon
You'll have the Vice Squad after you.
288008
Follow Up By: giffo - Sunday, Feb 17, 2008 at 20:54
And Jed Clampit !
Giffo
553292
Reply By: Member - Bucky (VIC) - Monday, Feb 18, 2008 at 09:41
Legal,, Legal,, legal,, watch for coppers !
Does anyone know the legal side of this ?
Bucky
288110
Reply By: Member - Michael J (SA) - Monday, Feb 18, 2008 at 15:14
Hi Lyndon,
Would a small commercial/swivel vice fit on the draw bar of
the T-Van??
Michael
288155
