duel batteries
Submitted: Tuesday, Nov 13, 2001 at 01:00
Graham
I have been told that a duel batteries can not be installed on my "4500 Gu patrol" as there no space available to set up reasonable size deep cycle second battery.Can anybody assist with info?
Reply By: Graham - Tuesday, Nov 13, 2001 at 01:00
Graham,
checkout www.tjmproducts.com.au in the section about their across oz trek, they took a GU petrol and had it fitted with a 15 plate second batt. but they did not say where they installed it.
hope this helps
1419
Reply By: Tim - Tuesday, Nov 13, 2001 at 01:00
I have a 3litre turbo diesal with dual batteries plus glinds shower in engine bay no problems 2nd battery fits between air filter and anti lock breaking plumbing on lhs not sure about 4500 petrol have you considered 2 in one batteries eg 2 batteries in one case similar size to one battery
1420
Reply By: Patrick - Wednesday, Nov 14, 2001 at 01:00
Graham - try the piranha.com.au site as they have an extensive list of battery trays on hand. I found recently that after many after market companies said no to my pathfinder installation that it was indeed possible. Do the research and you might be suprised what you will discover.
1427
Reply By: Don - Wednesday, Nov 14, 2001 at 01:00
I have a 4.5 litre GU Patrol , and fitted a second battery ... got a Pirana system . Cradle fits on passenger side behind air intake .
1431
Reply By: Chris - Sunday, Nov 18, 2001 at 01:00
Graham
I have fitted a dual battery to my GU 4500 patrol. The tray was supplied by a local 4WD accesories
shop from Piranah and required the repositioning of some of the clutch vacuum pipework and its canister. I also extended the end of the tray closest to the motor and this allowed me to fit the ODYSSEY ES12V1500 as described in a reply I sent to NIGEL'S Nov 8 question in this
forum.
1448
Reply By: Graham. - Thursday, Nov 22, 2001 at 01:00
Thank's to all that responded,I had a quote of $650.00 from TJM, for a piranha system including a deep cycle battery.
1465
