80series Landcruiser - fix squeaky back barn doors
Submitted: Tuesday, Feb 19, 2008 at 23:43
ThreadID: 54738 Views:7157 Replies:8 FollowUps:1
Does anyone have a good tip for stopping the back doors (split width vertically hung) on the 80series from squeaking? I've seen this tip on the net but wanted local feedback before I fork out the cash.
squeaky doors
cheers tony
Reply By: Bega Photographer - Wednesday, Feb 20, 2008 at 06:24
Have you tried adjusting the mechanism to take the movement out?
Might be worth a try, first.
Could save you eighty bucks if it works.
Regards,
Laurie.
AnswerID: 288394
Reply By: David - Wednesday, Feb 20, 2008 at 07:13
Hi TBudge,
l had the same problem back in 1997 when got my 1993 model. I put up with it for about 6 months trying everything, but in the end I went and got new parts.
Since then I have had no problems with the doors Squeaking, I have done about 270000 km since changed over in the last 10 years without a problem all over Aust.
I would not hesitate forking out the $$$$$ as it is well worth it.
Hope this helps,
David
AnswerID: 288397
Reply By: Member - Tour Boy (Springsure- Wednesday, Feb 20, 2008 at 07:22
you can put a little bit on electrical or gaffa tape on the latch, it works for a while and is cheap. This also lets you know exactly where the squeak is comming from so that you don't change the wrong parts.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 288400
Reply By: Kev & Darkie - Wednesday, Feb 20, 2008 at 07:24
You can get a dual cab conversions done and that totally eliminates the rear doors from squeaking LOL it costs just a little more than most other cures though ha ha
Cheers Kev
Russell Coight:
AnswerID: 288401
Reply By: desert - Wednesday, Feb 20, 2008 at 08:48
silicon spray on the rubbers, available at your friendly Supacheap store.
AnswerID: 288410
Reply By: Member - DOZER- Wednesday, Feb 20, 2008 at 15:43
Toyota make a upgraded catch made or covered in plastic, so there is no metal on metal, they were $75 years ago....or buy a better duke box
Andrew
AnswerID: 288450
Reply By: Geoff43 - Thursday, Feb 21, 2008 at 19:14
Tony
THE squeak is caused by the surface of the rubber bump stops on the right hand door becoming so glazed that they squeak where they make contact with the painted surface of the body.
You can reproduce the squeak by rubbing the tip of you index finger on the surface of the rubber bump stop.
The simple fix is to cut a piece of rubber 2mm thick as round as the bump stop say 25mm and stick it on the painted surface, where the bump stop makes contact with the body,use contact cement or Tarzans grip.
It really is as simple as that, my 80 has not squeaked
in the last 5yrs.
Geoff43.
AnswerID: 288660
Follow Up By: Geoff43 - Friday, Feb 22, 2008 at 18:18
Bump stops on the body not the door, I haven't looked at it for 5yrs , sorry premature dementure.
Geoff43.
FollowupID: 554175
Reply By: TBudge - Wednesday, Feb 27, 2008 at 00:00
Thanks for all your tips guys, I've tried sticking some small rubber spots on the two area's where the rubber knob/stops sit on the body/door (from Geoff43 - thanks mate) and that seems to have done the trick
cheers Tony
AnswerID: 289588
