Sand Flags
Submitted: Friday, Feb 22, 2008 at 11:16
Member - lyndon K (SA)
Yes me again!
We are about to travel for a year and was thinking it may be worth carrying a sand flag just in case. Not really in to desert travel but could end up in some beach dunes where we need one.
What is a good brand and where would i get it?
How do most people mount it? Would like it to brake down in to several bits for easy storage.
Thanks Lyndon
Reply By: time waster - Friday, Feb 22, 2008 at 11:19
We use an old telescopic fishing rod with the eyes removed and a flag attached to the top, its great for traveling when space is an issue.
Christian
288793
Reply By: Member - Phil G (SA) - Friday, Feb 22, 2008 at 11:27
I bought an old surf rod from Cash Converters for $20, and added an
orange flag. It flexes nicely - better than the other flags I've used before. just tape it to the bullbar.
288794
Follow Up By: Member - Kiwi Kia - Friday, Feb 22, 2008 at 12:48
I use my surfcaster cable tied to the bull bar and a bit of duct tape around the join in the rod just in case it vibrates loose.
554137
Follow Up By: Member - Phil G (SA) - Friday, Feb 22, 2008 at 14:29
Yep, ducttape around the join is a good move.
554148
Follow Up By: disco driver - Friday, Feb 22, 2008 at 15:48
If it was me, I wouldn't be using my good rod as a sand flag.
Would be a right proper bugger if you broke it on an overhead branch or similar BEFORE you got there. You may miss out on catching anything.
Much better to buy an old rod and set that up as the sand flag, duct/gaffer tape around the joins is a good idea too.
Disco.
554159
Reply By: Paul V Qld - Friday, Feb 22, 2008 at 12:20
Opposite Lock sell sand flags. I bought one and it worked
well. It is a one piece, but last time I was in there they had ones that were two pieces and screwed together.
288800
Reply By: Twinkles - Friday, Feb 22, 2008 at 13:12
Our club uses dome tent poles
288804
Reply By: Member - Doug T (FNQ) - Friday, Feb 22, 2008 at 13:41
look here
No over here
288806
Follow Up By: Member - Mick O (VIC) - Friday, Feb 22, 2008 at 17:47
I've got one of these 3.4 meter whips with the light as shown on this site. Great unit (didn't bother to connect the light up). Pretty hard to come by down south tho. Used pretty much exclusively by the mining companys. Pretty pricey too. Got
mine in Hedland.
Cheers. Mick
554169
Follow Up By: Member - lyndon K (SA) - Friday, Feb 22, 2008 at 20:25
Thanks Doug,just what i needed!!!!!
Cheers Lyndon
554193
Reply By: Davo_60 - Friday, Feb 22, 2008 at 18:43
Hello,
I am in need of a sand flag also for Simpson trip this year. I was thinking of attaching a flag to the top of the HF tapped whip on the front of the vehicle. Not sure if this would be high enough however.
Dave
288850
Reply By: Derek from Affordable Batteries & Radiators - Friday, Feb 22, 2008 at 20:40
I bought one at the mobility
shop for $15.00. (Most large centers will have one)
Used zip ties to hold it on the roof rack and it now sits behind the back seats for whenever I need it.
I used it for 10 days on the
Birdsville trip and only took it off when I got back to
Brisbane. It is a fibreglass one piece whip and a polypropylene flag.
Derek.
288869
Follow Up By: Outnabout David (SA) - Friday, Feb 22, 2008 at 21:37
Looks good Derek but if it ain't at the front and 15 ft of the ground it probably won't work due to the angles involved at least on steep hills. T
The problem with a lot of the fishing rod, or electrical conduit ones is that they are fine when stationary but have a habit of breaking with low branches.
The other one to watch is how flexible they are. It is amazing how many people use tent pole and think it looks good. problem is when they get moving a bit the air resistance on the flag just about bend it back to touch the roof making next to useless.
For $100 or so dollars get a proper one. Try www.outbackideas@three.com.au
554213
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Feb 22, 2008 at 22:05
Dead link but am quite happy with
mine thanks.
Did not get it to bend at at the speeds I was doing in the sand.
554219
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Feb 22, 2008 at 22:51
554233
Reply By: pradowolf - Friday, Feb 22, 2008 at 21:02
I looked around for a while , uses a squit pole and a friend of
mine had the squid pole from the
birdsville caravan park to about half way to big red before it snapped so i decided to buy a 3 piece fibregalss one from Outback Ideas , cost me 100.00 did the simpson without anyproblems and since i put the holder on the roofrack , i only used 2 pieces. Very good quality , all riveted.
Can recommend it.
288873
Reply By: Member - Mary W (VIC) - Saturday, Feb 23, 2008 at 17:20
If you keep an eye open at Aussie disposals they sometimes have sections of
tank whip areial available.Make it as long as you like and attack bottom section securely to bullbar Easy to dismantle and store.
Mary
289008
