hayman brake sender unit
Submitted: Saturday, Feb 23, 2008 at 13:41
gerrybhoy
just in the process of transferring my brake sender unit to a late 2004 120series prado gxltd. any info on the best place to connect the brake feed wire. vehicle is fitted with factory cruise control.
Reply By: Member - Graham H (QLD) - Saturday, Feb 23, 2008 at 14:17
Probably on the cold side of the switch on top ofthe brake pedal
288978
Follow Up By: Dunaruna - Saturday, Feb 23, 2008 at 23:59
Not necessary, each magnet draws about 2 amps max. Even for a tandem 4mm wire is sufficient.
554370
Follow Up By: Member - Graham H (QLD) - Sunday, Feb 24, 2008 at 19:01
I am in error above, I meant that the power wire comes off the out (cold) side of the brake light circuit as per wiring diagram. The blue or brake activation wire comes from the unit itself.
554476
Reply By: Dunaruna - Saturday, Feb 23, 2008 at 18:06
We always run a twin core all the way back to the trailer plug, that way you avoid any hassles playing around with cruise control etc under the dash.
289012
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Feb 23, 2008 at 21:48
I agree, bring a wire back from the tail lights. Cruise control, abs and other computer controlled items can be affected by the controller connected to the brake light switch.
289035
