3L GU - Heavier Caravan? - Dtronic?
Submitted: Sunday, Feb 24, 2008 at 09:00
ThreadID: 54866 Views:3407 Replies:10 FollowUps:3
Howdy forumites
Sold our old caravan. Seriously looking for another one now. Think we’ll end up with a van with an ATM of about 2.2-2.5T. Interested in views from 3.0L GU owners with heavier vans. Definitely not interested in smart ar_e comments by ZD30 knockers.
Found pulling old van (ATM ~1.6T) and well laden Patrol around Tassie last year that it was working real hard in some of the steeper areas – something I’ve not really experienced otherwise.
So wondering how people with 3L GU’s feel about towing vans near 2.5T ATM, what experiences they have had.
I'm thinking about a Dtronic (or similar) given our Tassie experience and the possibility of a heavier van. However, I’ve managed my car carefully due to past ZD30 issues so I’m nervous about that. On the other hand I know / have met a few people who have run Dtronic’s in ZD30’s over a long period with no problems. Again, I’m interested in your thoughts about fitting a Dtronic.
Thanks in advance.
JD
Reply By: Member -Dodger - Sunday, Feb 24, 2008 at 10:22
From all reports that I have seen, the chip makes the 3ltr a lot better vehicle.
Try this site with your question as some members have had their 3ltr ZD30 chipped.
http://groups.msn.com/Caravanersforum/messageboard.msnw.
Cheers Dodg.
AnswerID: 289080
Reply By: Lyds- Sunday, Feb 24, 2008 at 10:32
I have a dtronic and I'm only towing a chunky offroad CT, its still hard work on some inclines.
However I know what the truck was like before the dtronic, so I could never imagine towing without it.
AnswerID: 289082
Reply By: Member - Captain (WA) - Sunday, Feb 24, 2008 at 10:37
Hi JD,
I have been running a Dtronic for 100,000kms and would recommend it. I have also blocked of the EGR and turned down the turbo boost to compensate. This made virtually as much difference as the Dtronic.
I haven't changed the exhaust but from what i have read fitting a larger system will help more, plus lower EGT's. If i was keeping my vehicle longer (its about to go) it is something I would defineltly do.
I used to tow my van with this (only ~1600kg) and it was an excellent setup with plenty of power, I could even overtake comfortably!
Captain
AnswerID: 289084
Follow Up By: Dunaruna - Sunday, Feb 24, 2008 at 10:50
"I have also blocked of the EGR"
It's a common mod, and it works, but it's something you don't want to be advertising seeing as it's highly illegal.
FollowupID: 554411
Follow Up By: Member - carl R (QLD) - Sunday, Feb 24, 2008 at 15:31
Dunaruna
At what stage did you block the EGR on the inlet or outlet
FollowupID: 554449
Follow Up By: Dunaruna - Sunday, Feb 24, 2008 at 18:29
I didn't and won't. I was quoting the post above by Captain.
FollowupID: 554470
Reply By: Notso - Sunday, Feb 24, 2008 at 11:02
Brother in law has a DTronic in his patrol and it certainly helps.
He tows an off road pop top around 2.2 tonnes. It still works hard on big hills though.
AnswerID: 289088
Reply By: Andrew(WA) - Sunday, Feb 24, 2008 at 12:33
I had a series III manual with a Dtronic. The extra power and driveability is surely noticeable and towing on the straight flat roads is a pleasure.
I always found the biggest drama to be taking off on an incline. Not good for that poxy clutch they put in them.
Every other aspect I found it a very good vehicle.
Personally I think the Dtronic saved me a little Diesel and once moving power was more than adequate when needed overtaking and pulling up hills.
I never weighed what I was towing but fulling loaded with the kids etc I's be pulling about 1.5 -1.7 ton.
Can't comment on the Patrol auto but I now have a TD100 with the auto box and will never bother with a manual again.
I sold the Patrol purely because of the (engine may go bang) issue. No other. A real shame because I loved it in every other way.
AnswerID: 289097
Reply By: Motherhen - Sunday, Feb 24, 2008 at 14:28
Hi JD
We have towed a heavy van (with 2.2 TARE) with a 3ltr auto. Did it well, including Tasmania; only limiting factor was the auto. Legally, it can tow to 2.5 t due to braking power of the auto. On two occasions, from a standing start on a very steep slope it was slow - due to the auto not the motor, which is the same motor as in the manual version. We have taken it with the van up some 'goat tracks'.
We chose not to make any modifications, but added the EGT and boost gauges so we could ensure we didn't stress the motor. It is easy to cut back a little if you can read what is happening. Although it did the job, long term towing a heavy van MAY effect the longevity of the motor. Doing modifications MAY also effect the longevity. I can only say may, not would. I would not choose the Patrol to pull a really heavy van long term, even tough it is the most comfortable vehicle we have owned. I would not add a chip or make other modifications that some people have made; there has to be a down side.
With 7.3 litres now, we have the capacity to load the van for long trips with power to spare, and still have the convenience of auto. We still won't race up hills just because we can. Take it easy and pull over to let others past, what ever you drive.
AnswerID: 289113
Reply By: Member - Bob K (QLD) - Sunday, Feb 24, 2008 at 15:22
Hi JD,
We have a late 2001 3.0 Patrol that has done 150,000k's much of that towing a 2.2t van. Fitted a Steinbauer "P Box" a couple of years ago and that was well worth the $1400 spent. Have just recently fitted a 2 3/4" Beaudesert Exhaust and would say that it has really made a significant improvement on the towing performance. A leaking intercooler core has been my only issue.
bk
AnswerID: 289119
Reply By: pauljohnston - Sunday, Feb 24, 2008 at 18:08
These vans are just getting flasher and flasher. They even come with ATM's now? (automatic teller machines). That must come in real handy when you are out in the bush and run out of cash!
PJ.
AnswerID: 289136
Reply By: Member - Graham H (QLD) - Sunday, Feb 24, 2008 at 18:53
If your Patrol is an Auto make sure for sure itsATM is UNDER 2500KG.
I made the mistake of buying one that has an ATM of 2564kg which is not legal with an AUTO 3.0ltr Patrol.
Had to upgrade to a Cruiser to fix it and its the best $23,000 I ever spent.
AnswerID: 289152
Reply By: jdwynn (Adelaide) - Tuesday, Feb 26, 2008 at 06:16
thanks for your comments everyone - much appreciated, JD
AnswerID: 289416
