Nuvi 760
Submitted: Sunday, Mar 02, 2008 at 09:45
Izey76
Just a quick question about whether or not you can load Shonky and T4A maps into the 760 as I am leaning towards buying this unit for the lager screen compared to the garmin gpsmap60csx.
Thanks in advance it is so difficult trying to choose unit with everything available at the moment.
Clint
Reply By: res.q.guy - Sunday, Mar 02, 2008 at 10:11
Hi Clint
Yes you sure can, I did it to my father's 760 last month.
Neil
290348
Follow Up By: Izey76 - Sunday, Mar 02, 2008 at 10:46
Thanks Neil has he used it on any trackwork yet as this is the main reason for getting one.
Clint
555691
Follow Up By: res.q.guy - Sunday, Mar 02, 2008 at 11:58
Hi Clint
No he hasn't used it on any tracks yet, so sorry I can't report on that.
I have both T4A and Shonky on my 660, and on my 60Cx.
Hope to get OzTopo one day.
Haven't done much track work since installing, but around the suburbs and outer
metro, the roads come up similar to City Navigator (but without auto routing) on the 660, but show extra features such as old mines quarries etc. I use the 60Cx for walking, fishing and boating in the tinnie.
Neil
555699
Reply By: Member - Doug T (FNQ) - Sunday, Mar 02, 2008 at 10:41
Clint
Yes you can but not in the unit but on the SD card , as for shonky maps why would you bother , the T4A will have all you want .
290351
Follow Up By: Izey76 - Sunday, Mar 02, 2008 at 10:44
Thanks Doug yeah I was not sure what the T4A maps were like as this is going to be my 1st GPS and there is so much info to go through.
Clint
555690
Follow Up By: Member - Doug T (FNQ) - Sunday, Mar 02, 2008 at 10:54
Clint
Check my gps webpage about T4A and or OzToppo V2
Info about OzToppo
555693
Follow Up By: Skippy In The GU - Sunday, Mar 02, 2008 at 23:40
Yes you can add the Shonkymaps onto the main unit, it creates another file called gmapsupp.img the base map is called gmapbmap.img and the loaded City Nav Aust2008NT file is called gmapprom.img.
You will need to cut and paste the gmapsupp.img if you decide to remove it otherwise it stores it in the invisible trash folder .
Best to add them to the SD card just incase you make a mistake.
If you do want to try it copy and paste everything in the Garmin folder into a backup folder
555876
