honda ex350 generator
Submitted: Saturday, Mar 08, 2008 at 21:12
kcandco
I've just bought a honda ex350 generator (2 stroke) 2nd hand in great condition. What can I realistically expect expect this generator to power? Will it power a bar fridge, battery charger, lighting (flouros)?? According to the manual specs are rated output 300VA, max 350VA
How much should I have paid for it?
It only has an output of 4 amps at 12v (manual says 6 amp) and am wondering if there is any way to increase this?
Thanks Kc
Reply By: Member - Cruiser (NSW) - Saturday, Mar 08, 2008 at 22:22
Can you tell me how much you paid for it, because I have a chance to buy one as
well and dont kn ow what to offer.
I only want it to recharge the battery on my caravan via a smartcharger, so it probably suits my needs.
Cruiser
291691
Follow Up By: kcandco - Sunday, Mar 09, 2008 at 21:57
Hi Cruiser
I paid $45 for this one and it is in very good condition. The previous owner has bought a winnebago and is selling all their caravaning and
camping gear. I think it is a bargain at that price considering he paid $830 for it according to receipt about 9 -11 years ago. From what i have been able to find on the net it seems this model finished 1999 and from the serial number I think this would be one of the later sales. You can download a manual for it at the Honda website. It starts first pull every time hot or cold and runs very smoothly and pretty quietly. I have so far run 2 x 4ft fluoros (72watt), trailblazer fridge, drill, and grinder (separately that is). It will not start my small bar fridge or run my battery charger. I don't know if it should or not. I have read on 4 seperate sites that fridges prefer pure sine waves and the honda is not. I wonder if the battery charger also requires pure sine wave electricity?? What size and brand smartcharger were you thinking of using?
regards Kc
557197
Reply By: obee - Sunday, Mar 09, 2008 at 09:35
with less than fifty watts you wont be powering much except charging batteries. A reasonable drill starts at about 500 watts. One four foot fluro takes forty watts.
12 volt waeco type fridge takes nearly four amps when it runs.
Definately not worth buying an invertor for it but yeah its a great backup for the battery.
There is good info here on this site under electrics.
owen
291736
Follow Up By: kcandco - Sunday, Mar 09, 2008 at 22:01
Hi Owen
I believe it puts out 300 watts @240 volt. On 12 volt it is rated at 6 amp but I could only measure 4 amp with multimeter when connected to a battery being recharged.... but then again the battery was close to full charge.
regards Kc
557198
Reply By: bruce - Sunday, Mar 09, 2008 at 10:50
Had one a few yrs ago....top little machine...runs battery charger , waeco 50l , lights , radio . tv...no problems at all and very economical and very quiet...now have 1kva same brand.
291747
Follow Up By: kcandco - Sunday, Mar 09, 2008 at 22:09
Hi Bruce
what type of battery charger did you use. I found when I hook up
mine the charger can only put about 1.5 amps into the battery but when the same charger is connected to 240 volts that increases to 4 or 5 amps. Any idea why this would be so? Also it will not start my bar fridge which uses 50 watts continuous and about 180 watts at startup according to my power meter. I wonder if this is because fridges prefer pure sine electricity which the generator does not provide or am I not getting an accurate startup wattage reading from my meter.
thanks Kc
557200
Follow Up By: bruce - Monday, Mar 10, 2008 at 10:18
I used a 240v 6 amp charger and usually just ran the genny at half pace (150w)..tight bugger I am ...and it charged the 105ah battery....seemed to run everything else o.k. as
well ...hope you have not bought a dud...cheers
557234
Follow Up By: kcandco - Monday, Mar 10, 2008 at 19:07
Thanks Bruce I have an old Arlec charger in the shed... will dig it out and see how it goes.
Kc
557298
Reply By: Member - Roger B (VIC) - Sunday, Mar 09, 2008 at 22:42
My brother recently gave me a Honda ex350, and although we haven't put it to the test yet, it seems to run fine. I've just played around at home with it with lights etc. We'll be putting it to the test this Winter when, after fishing & crabbing at Groper Ck., we'll be heading to
Rubyvale to
camp out on the
gemfields for a few weeks. I only intend to use it as a battery charger cum back up. Cheers.
291846
Reply By: DesF - Wednesday, Apr 02, 2008 at 19:34
Hi, Kc , Just a few "facts" on the Honda EX 350. I have had one for 14 years and have really tested it out.
It will run 2 Engle friges and a 150w portaflood,( out bush) or 2 portafloods ,
They put out 100 watt DC which will charge your battery Ok , it will put in enough to start a falcon in 10 mins ( flat , no dash lights) ,
But you have to watch that it does not over charge, it will run a small K mart battery charger as
we run our's on 50 to 1 mix Stihl chainsaw oil. runs clean and no smoke , will run just on 4 hrs on a
tank of
fuel ( 0.7ltr from memory) also when finished using ( to store ) always tip out the last of the
fuel and then run it on low until it stops , then next time put in fresh
fuel and I bet it will start second pull even 6 month later.
I paid $800.00 when I got it , but worth every penny.
You can carry it in side when full of
fuel just make sure you lock the cap vent.
Cheers Des.
296189
Follow Up By: DesF - Wednesday, Apr 02, 2008 at 19:42
Hi, I notice some one talking sine waves etc for fridges . we have been using ours every year ( 14) a couple of weeks or more at a time and it has not hurt the Engels.
mine is 14 years old and mates is 29 years old.
Also when ( if ) we have a power black out at home I run a light and the sml Tv of it , you cant even hear it running under the back verandah, and it wont worry the next doors either.
I did read of a chap who's battery died out bush and he tied the Honda on the bullbar and ran it to the crook battery and it got him to where he could get a new one.
Cheers Des.
562278
Follow Up By: kcandco - Saturday, Apr 05, 2008 at 11:43
Hi Des
Thanks for the tips.
The pure sine wave was in reference to a small 240 volt bar fridge. Have you ever tried running one from your generator?
thanks Kc
562848
Follow Up By: DesF - Saturday, Apr 05, 2008 at 15:07
Hi KC , no I have not tried it on my 70ltr bar fridge but when I fire it up June long weekend I will put it on and try it,
I have found it is a lot better to cool the engel down on the power before we go, then it holds it easily.
I reckon it would probabley run the bar fridge if it was already cold.
Cheers Des.
562869
Follow Up By: kcandco - Saturday, Apr 05, 2008 at 20:24
Hi Des
I would be interested to hear how you go. I was talking to the brotherinlaw today who is into electronics and he thinks my electronic power meter (ex Jaycar $39.95) may not be showing the true peak power drawn by the fridge at startup. Does your Kmart battery charger connected to the 240 output put more charge into the battery than the generator DC output which is supposed to put out 6 Amp?
regards Kc
562916
