Air con not cool enough at idle.
Submitted: Sunday, Mar 16, 2008 at 21:07
Twinkles
I've had my car put in for air con check twice. They gased it up and second time cleaned the fins(??) Still not as cool as my old (99) Hilux and runs warmer when standing still idling. Any advice please. It also takes a long time to cool sufficiently. Car only done 80,000kms.
Reply By: Member - G N (VIC) - Sunday, Mar 16, 2008 at 21:21
me Rodeo also like you say, yet ne old 60 seis is coooooooooooooool
Took it back to holden a few times but "its all good story" so NO MORE holdens!
GN
293011
Follow Up By: warfer69 - Monday, Mar 17, 2008 at 01:07
so NO MORE holdens!
Well i have had holdens ever since my ass sat in one for my licence..Had them all my life but you will not see my ass in one again as an owner..
I believe from new if you get a good one your troubles wont start for about 4-5 years then its all down
hill..My brother in laws Rodeo is three or four as a guess and the central locking system is crapping out,he has had it since new..
558670
Follow Up By: Mike Harding - Monday, Mar 17, 2008 at 08:00
What is the exact problem with his central locking?
558682
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Mar 18, 2008 at 16:47
So you are not going to buy a Holden, presumably an Australian made Commodore because your brother in laws Japanese made car is having a minor problem.. Im having trouble getting my head around that one.. Michael
559010
Reply By: Gone Bush (WA) - Sunday, Mar 16, 2008 at 21:24
I reckon it's something to do with the "new" environmentally friendly gas used these days.
Older vehicles kept the temp right down.
293014
Reply By: Bushtrek - Sunday, Mar 16, 2008 at 22:43
Check that your hot
water switch completely closes.
As
well if the car aircon has been serviced they are required to ensure that it reaches 5 celsius at 1500 rpm.
If they haven't done this then ask them to recheck, and fix the problem
293030
Follow Up By: Twinkles - Sunday, Mar 16, 2008 at 23:05
Hi Bushtrek. Where is the 5 degrees measured? Would that be in the cab with recycled air? Who says they have to do this so I can quote? Thanks for your advice.
558654
Follow Up By: donks1 - Monday, Mar 17, 2008 at 07:57
hi there
its done with a thermometer in the centre outlet in the car
donks
558680
Reply By: oz doc - Sunday, Mar 16, 2008 at 22:57
If it needed gassing up then doesn't that mean it has a leak? As far as I know air cond units don't "use" gas. ? take it to another air cond mechanic for second opinion. Something sounds suss.
293035
Follow Up By: Member No 1- Monday, Mar 17, 2008 at 08:19
youe right oz doc...aircons dont "use" gas...unless its leaking out it does not deplete or wear out etc etc
558684
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Mar 18, 2008 at 16:51
Member #1... I change the air in my tyres because it goes soft after a while... Dont you? :) Michael
559011
Follow Up By: Member No 1- Tuesday, Mar 18, 2008 at 17:01
no...hahaha..i use dry nitrogen
559015
Reply By: Twinkles - Sunday, Mar 16, 2008 at 23:03
Thanks all. The older Hilux had the same gas system. I'll check heater lever and get them to check temp.
293036
Reply By: Dave B (NSW) - Sunday, Mar 16, 2008 at 23:28
Twinkles, the new gas they have to use nowadays isn't as good as the older (I think R12) gas they used to use a few years ago.
Unfortunately, but that's the way thinks are going now.
I was told not so long ago that the next generation of engines we get in our trucks, you will be able to wipe a white cloth inside the exhaust pipe and not get it dirty, that's how good the emission control will be.
Downside is that we will use more
fuel. Work that out.
At 1.6 Kms per litre at the moment, it doesn't sound good!!
Dave
293038
Follow Up By: Member No 1- Monday, Mar 17, 2008 at 08:22
the newer refrigerants in a r12 system is a little less efficient..
but in systems designed for r134a the aircon system should be just as effective as any other..... if designed correctly of course and one assumes they have been
558685
Reply By: Member - Davoe (Yalgoo) - Monday, Mar 17, 2008 at 02:28
cant help you but i can tell you 2 things
1) new gas works just fine
2) when you take your vehicle in with dodgy aircon the first thing they do is regas it wheather it needs it or not and give it back - hopefully you wont return.
you need to take it to an aircon repairer not a regas merchant.
i took
mine back and spelt it out that i specifically said i want the aircon fixed not regassed and any further repairs there wasnt a hope in hell i was paying for another regas.
.... i got it back fixed and even thought the gas would have had to be purged there was no regas charge
293045
Reply By: Nick R (VIC) - Monday, Mar 17, 2008 at 08:10
We had problems with our 80 series, they ended up putting a dye in the system. after a week or so they had a look at night and that found the leak. the dye shows up under UV light and is best viewed at night....
Nick
293058
Reply By: inspired - Tuesday, Mar 18, 2008 at 17:04
While it is true the new refrigerant is not as good as the old R12, it is still very effective -- certainly keeps the cabin very cool despite 40° outside.
If the system was "regassed" as claimed, that indicates the old gas leaked out. And that means an existing leak which will allow the new gas to go the same way. Regassing is not good enough -- the source of the leak must first be found and repaired.
293375
