Canning Stock Route Feedback
Under the interactive map on the Right side there is a "Get Waypoints" button - it that an upcoming feature or been 'disconnected'?? I guess I can do it all manually as the waypoints are recorded above for each point of interest but it would be very helpful if they could be downloaded. Anyone know anywhere the waypoints for the CSR can be downloaded ??
Reply By: KiwiAngler - Tuesday, Mar 18, 2008 at 16:51
mmmmmm - looks like the hypertext link isnt working i.e 'disconnected'
I used it a few months ago to d/l the waypoints without any problems
Contact David at ExplorOz and ask him what the go is
AnswerID: 293371
Reply By: Member - Duncan W (WA) - Tuesday, Mar 18, 2008 at 20:44
If you use the map and place the curser over a spot the coordinates (Waypoints) appear on the top LHS of the map. Creat your own points by following the map tha way you can create as many or few as you want.
Dunc
AnswerID: 293440
Follow Up By: Member - Duncan W (WA) - Tuesday, Mar 18, 2008 at 20:45
Re read you post looks like you already found what I found.
Dunc
FollowupID: 559075
Reply By: ExplorOz Team - David - Wednesday, Mar 19, 2008 at 20:15
swh,
it is a work in progress sorry I have not been able to add the GPX download just yet - it is on the task list.
AnswerID: 293659
Follow Up By: Member - Oppikofer L (Int) - Monday, Mar 31, 2008 at 00:50
g'day David,
any idea when you will be able to add the GPX download to the CSR page?
greetings from the othere side of the planet - lukas
FollowupID: 561747
Follow Up By: Member - Oppikofer L (Int) - Monday, Mar 31, 2008 at 01:02
g'day David,
just noticed that the coordinate reference system used to provide the coordinates is GDA 94.
in my Garmin GPS device (60CSx) I can oly find GDA.... not GDA 94. Is there a difference between GDA and GDA 94? or is it the same?
hope you find the time to enlighten a novice in navigation -thanks in advance - lukas
FollowupID: 561748
