troopy brake lights
Submitted: Sunday, Mar 23, 2008 at 12:08
darrell.QLD
point is i havent got any/none/ i changed every globe and
every fuse i could find,all the ones near the accel pedal,
and the 3 inside the little black box""power outlet""....
everything else on the old girl works fine,including tail lights..
any ideas?? 1991mdl.. thanks in advance
Reply By: The Geriatric Gypsies - Sunday, Mar 23, 2008 at 12:14
check the switch attached to the brake pedal
steve
294207
Follow Up By: darrell.QLD - Sunday, Mar 23, 2008 at 12:17
steve, the little pin is going in and out with the pedal////
can the switch itself be stuffed???
560011
Reply By: The Geriatric Gypsies - Sunday, Mar 23, 2008 at 12:54
yes switch can be stuffed you need a multimeter or 12v test lamp to test power on each side of switch
it is not uncommon on a lot of cars for this to happen fords are renowned for it
steve
294213
Reply By: Member - Nev (TAS) - Sunday, Mar 23, 2008 at 20:29
Hi there,
put a temp short acrosss the switch and see if they come on. That should quickly prove the switch if you don't have a meter.
Rgds
tigertas
294278
